fuse help
Old Jun 28, 2008 | 08:19 AM
WildAngel81167's Avatar
WildAngel81167
4th Gear
Default fuse help
The switch to my gas tank door is not working...found the release in the back. I am sure it is just a fuse, but single woman and working long hours.....need a quick fix from you guys!
Old Jun 28, 2008 | 08:43 AM
itzza427's Avatar
itzza427
You have the right idea,Check the fuse first. If thats goos just start moving down stream and follow the power to the button,then if its getting to the solenoid .Grounding straps can come into play as well. I'm sure there will be members with more experience in this area will be jumping in!!
Old Jun 28, 2008 | 09:36 AM
02MillenniumVette's Avatar
02MillenniumVette
And I wouldnt post that you are a single woman on this forum, especially not in Off Topic.
Old Jun 28, 2008 | 10:07 AM
c5streak's Avatar
c5streak
Fuse #32 in the passenger footwell, 15 amp. Runs the fuel door, traction control, fog lamp, and trunk release switches.
To fuse help
