throwing code c1214 help
Old Jun 29, 2008 | 06:57 PM
FireMouth's Avatar
FireMouth
3rd Gear
Default throwing code c1214 help
Where is the relay for this i cant seem to find it? or is it even a relay i should be looking for?
Old Jun 29, 2008 | 07:02 PM
FireMouth's Avatar
FireMouth
3rd Gear
oh almost forgot .. its causing the car to go into reduced power mode if that helps you help me
Old Jun 29, 2008 | 07:11 PM
motogib1's Avatar
motogib1
Ah yes, many on here including myself have had the dreaded 1214 C code. This usually means failure in the EBCM (electronic brake control module) Did your service ABS/Tractions control light come on? First thing use the electrical stickies at the front of the tech section as a reference on how to check the grounds. There is a particular ground to chec for this case, it is on the right side of the engine compartment. You can check your EBCM connections also. Usaually, the EBCM requires repair or rplacement. Fear not, the module can be repaired inexpensively by ABSfixer.. You will have to remove the module yourself. Is a minor PITA but you can do it. You can ship the modul to ABSfixer and they will repair it for $150 Total cost including shipping should not be more than $250. Do a search on 1214C and you can get all the info you need.
Old Jun 29, 2008 | 07:27 PM
FireMouth's Avatar
FireMouth
3rd Gear
Thanks for the info and the quick response! ill start lookin into it. thanks again
To throwing code c1214 help
