I was driving yesterday and my display for the temp readout and the screen was blank. I hope it's just a fuse if any one has had this happen to them please let me know....
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Well don't panic just yet.
I know "Englandgreen" did a write up on re-soildering the connections in there.... it's not hard from what I remember... try a search for "HVAC display" or something... I'll try as well.
Thanks but after skimming the thread it looks like it's more for dim displays than no displays... I was kinda looking for a quick fix. who isn't. I will take a cruise and see if I can see anything at all on the display...
That is the difinitive thread on the Forum...
Short answer... bad solder joints... circuit board needs to be re-soldered...
The thread gives you DIY instructions.
If you are not comfortable doing it yourself
David Ruberg CF ID Mandigital will fix it for about $50 including a 5 year guarantee
His e-mail is digitalguy_1@charter.net
I will try that sounds quick and easy... Just curious did you used to own a ford... Hitting them seems to help (If that doesn't fix it get a bigger hammer)
Then we'll see a "WTB a new screen. Cracked my @&#@%# display!!!!!" thread
Feel your pain. I am sure you have bad solder joints, tapping the screen makes the chip contacts stronger and makes the display brighter for a while before going dim and out again. I resolderd (did a **** poor job) the joints and that worked for a while but the display finally gave way. I recently bought a used unit for $33 and swapped the boards out and have a perfect working display again. Should not cost you more than $100 for a used one or $50 for repairs.
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
