traction control
Old Jun 30, 2008 | 02:24 PM
cavalrycop's Avatar
cavalrycop
Default traction control
Hey newbie here just bought a 1999 with 6 speed.When I corner the vehicle agressive but not to the point of losing traction it cuts back power to nothing.The display says traction control active.It started doing the same driving straight with just mild acceleration? It cuts power all way out when i switch traction control off it rests? Any ideas?Thanks
Old Jun 30, 2008 | 06:06 PM
hyprsprt's Avatar
hyprsprt
do u have custom wheels?
Old Jun 30, 2008 | 06:39 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
check your tire size compared to the stock size. If there is too much differance it causes the TC to engage
Old Jun 30, 2008 | 07:22 PM
greg252's Avatar
greg252
Hey.....I'm newbie too......I would like to go on Mont-Tremblant racing track for lapping and is it better to activate or not the traction control ??
Old Jun 30, 2008 | 08:21 PM
cavalrycop's Avatar
cavalrycop
Yes it has aftermarket wheels on it.Can it be fixed or adjusted for wheels?
Mike
Old Jun 30, 2008 | 09:08 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Mike
More important than the wheel size - what size are the tires front and back?
The traction control system will activate if the rear wheels are found to be spinning faster than the front wheels. Obviously - if you lose traction on the rear wheels on either a slippery surface, or you apply too much throttle to cause wheel spin, the traction control system will activate.
But if the rear tires are either equal or shorter than the front tires, the system will detect the rear wheels spinning faster than the fronts and will activate T/C.
This is how the T/C system works - it compares the rate of spin front vs. back, and if the back is spinning faster than the front it will apply brake to the faster spinning wheels.
Old Jun 30, 2008 | 09:42 PM
cavalrycop's Avatar
cavalrycop
Darn that must be it they are285 20 inch rear and 245 35 20inch in front! can computer be adjusted?Am I screwed? What problems will this cause?
Old Jun 30, 2008 | 11:37 PM
blacksedan87
The 285-20x20 in back is 24.49 overall diameter and the 245-35x20 in the front is 26.75 overall diameter, meaning the back tires are almost 1.75" shorter than the front.
That's your problem. You need a taller tire in back than the front. The only way around this is to change the tires.
Here's a handy tire calculator to help you out....
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Jul 1, 2008 | 02:57 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I'd like to see how she sits with those tire dimensions! It would almost have reverse rake!
Old Jul 1, 2008 | 06:42 AM
DefenderC5's Avatar
DefenderC5
Blacksedan87 nailed it. I do want to see pics of this car with these wheels/tires though.
To the OP: Did you just buy them? Or buy the car with them already on there?
Old Jul 1, 2008 | 07:51 AM
hawks9999's Avatar
hawks9999
I would like to see some pics as well. Very interesting setup.
Old Jul 1, 2008 | 09:15 AM
cavalrycop's Avatar
cavalrycop
they are 285 30 20 in rear and 245 35 20 in front.I bought the vehicle with them already on them.The traction control is saying service traction control so I guess its something else?the overall diameter is .02 larger in front dont know why somebody did this but drives ok.I will be looking to replace them as soon as I can find other rims.Rides fine now
Old Jul 1, 2008 | 09:50 AM
cavalrycop's Avatar
cavalrycop
dont know how to post a pic sorry
Old Jul 1, 2008 | 11:49 AM
DefenderC5's Avatar
DefenderC5
Whoever put those wheels/tires on F'd up. Better off selling them and getting some proper sized wheels. Depending on your budget you can get the stock 17/18 or 19/20 combo. The tires are what geeked up the offset though... theres a couple guys on here running 20/20.
You can post a picture through a third party link/upload site like photobucket.com
Old Jul 1, 2008 | 12:08 PM
blacksedan87
Here's a link to a thread on the Help Forum that explains the magic of posting pictures - click here!
Here's another that explains the use of Photobucket - click here!
Jake is right - I'd sell the wheels, or at least the fronts if you can find a 19" front, get the proper sized tires and you should be good to go. If you want to PM me for help, feel free to do so. I can help you choose the right sized tires if the whole thing confuses you.
Old Jul 2, 2008 | 01:34 AM
itzza427's Avatar
itzza427
Press and hold your traction control button for about 5 seconds after "traction control off" displays,,,,then you'll get "Competitive Driving" display.This will let you spin the tires while keeping the stability controle feature.
Old Jul 2, 2008 | 01:44 PM
Slick Rick's Avatar
Slick Rick
Will the competitive driveing mode come up on a 97 A4 that way also. Thanks Rick
To traction control
Old Jul 2, 2008 | 02:20 PM
blacksedan87
No - competitive driving mode is a function of Active Handling, (RPO JL4) and did not become available until mid-year 1998.
Old Jul 10, 2008 | 09:51 PM
cavalrycop's Avatar
cavalrycop
replaced plugs and wires cleaned the grounds.I am not throwing codes and am driving with traction control in regular mode! No more issues under hard cornering or acceleration. The tires were not the problem.Works fine with 20s front and rear.
Old Jul 10, 2008 | 10:00 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Funny how that works, isn't it?
