Anyone using Canton oil cooler?
Old Jun 30, 2008 | 11:00 PM
Vetteguy2008's Avatar
Vetteguy2008
Default Anyone using Canton oil cooler?
Canton oil cooler's using a sandwich adapter that mounts between the engine and the spin-on oil filter. So do you need to use new shorter oil filter and what is part number?
Thanks,
-Mike
Old Jun 30, 2008 | 11:10 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I don't know if you can find a shorter filter than stock, If it fits between the block and the filter I would pass because the filter would be way too low and hit something.
