Attention High mile owners
Old Jul 1, 2008 | 09:19 AM
Cal Vette's Avatar
Cal Vette
Default Attention High mile owners
I just aquired my first C5. Paint & interior flawless. Trans. tires,waterpump & belt replaced. Looks to be well maintained. I picked it up at a great deal. Only down side is the 112k miles. My question to you all is, should I be concerned? How many miles can these reach?
Any high mile C5's out there driven daily, if so, how many miles on your C5?
Old Jul 1, 2008 | 09:24 AM
rws.1's Avatar
rws.1
My '01 is a DD... 118K miles.
The LSx engine was designed for 250K mile swithout major rebuilt...
There are several posted here over that 250K.
Old Jul 1, 2008 | 09:49 AM
ericdwong's Avatar
ericdwong
136K here on a '98. Driven almost every day... even in the snow. Towed trailers.
I had to rebuild 3rd gear synchro a while ago cause it started grinding. I did that when I had my trans out cause the slave cylinder died. That was the most debilitating failure.
Old Jul 1, 2008 | 10:18 AM
vet02's Avatar
vet02
Close to 120k on my 02. I owned it since new and had to replace the EBCM and clutch. Otherwise no problems. Still runs like new.
Old Jul 1, 2008 | 11:43 AM
Enemy's Avatar
Enemy
my 02 si a dd and has 63k on it, my 99 t/a was over 120k, ran fine and was modded
Old Jul 1, 2008 | 11:47 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The C-5 Corvette is a strong platform. Created to run along at speeds in the 170's to 180's and in some cases, above that. A lot of engineering went into its design. Will they last??? Of course they do as long as they aren't abused and they are taken care of. Nothing lasts forever therefore there will be issues but if you fix them as they appear, it will keep right on going. I gave away my high mileage '99 to my son who picked it up here in May (S. Calif.) and drove it back to Virginia where it is now. When I gave it away, it was at 310,000 and I hear its almost 316,000 now, still running strong.
Old Jul 1, 2008 | 11:48 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
118k 2002 MY Z06, former USAF F16 crew chief, the C5 is simple to fix
I won't buy a C5 w/ <100k miles, if I'm spending more than 20k, it's going to be a C6
Old Jul 1, 2008 | 12:15 PM
bucwheat's Avatar
bucwheat
The days of hundred thousand mile engines are gone.
Old Jul 1, 2008 | 01:18 PM
Cobra_4's Avatar
Cobra_4
St. Jude Donor '09
Good to here everyone getting crazy high mileage. Makes me not afraid of buying the 02 I am looking at for a dd with 60,000 miles on her.
Old Jul 1, 2008 | 03:35 PM
Patman's Avatar
Patman
My 98 isn't as high in mileage as some on here, with 95k on it, but I am confident that it'll still be running perfectly even when I add another 95k on it. This car still feels and runs like a brand new car! It's easily been the most reliable daily driver I've ever had! It has only had two repairs in the 4 years I've owned it, the first was the digital display for the climate control going dim (a common C5 issue which is easily fixed) and the ECM died on me (due to corrosion) back in early 2006. Since that time, it hasn't needed any repairs! I drive this car 50 miles a day to work and back, even in the winter time. I couldn't possibly imagine driving some slow and boring 4 cylinder car to work everyday!
Old Jul 1, 2008 | 03:59 PM
darguy's Avatar
darguy
Default 'New' daily driver.
I just picked up a 110,000 mile FRC on Sunday, tranny and clutch were done in the last year by the PO, as was the paint. This is my 'new' daily driver - so fingers crossed. I'll be putting about 500 miles a month on it, and gas just hit over 1.50 per litre (about $5.70 per gallon). Go big or stay at home, I figure.
Old Jul 1, 2008 | 04:49 PM
OIF2XVET's Avatar
OIF2XVET
I have a 00 daily driver with no issues 130,000 on the clock and have only done the basic maintnance on her
Old Jul 1, 2008 | 06:24 PM
zo6lou's Avatar
zo6lou
a friend of mine has a 01 ZO6 with 185,000 miles, running strong, original clutch, one water pump and several sets of brake pads and tires, otherwise thats it
Old Jul 1, 2008 | 07:03 PM
Oldvetter's Avatar
Oldvetter
98 daily driver Coupe with 113,600 miles. Only 2 problems, one headlight gear and one oil pressure sensor. Great Car. I heard engine is good for 200,000 miles.
Old Jul 1, 2008 | 07:58 PM
Old Rotor Head's Avatar
Old Rotor Head
Just turned 120k on my DD. Had it since new and I'm still in love with the C5.
4 sets of tires, shocks, brakes, 4 batteries, clutch system, belts, interior foam, seat covers, rear carpet (coupe), gas, oil. Much of what I changed was by choice not need.
Old Jul 2, 2008 | 09:26 AM
Cal Vette's Avatar
Cal Vette
Here she is, my 112k C5!
Old Jul 2, 2008 | 10:00 AM
itzza427's Avatar
itzza427
I have a club buddy that has a 110k coupe that is a regular at the strip,,runs great!! Called an add when I was looking,It had 225K and was still going strong.(They were a LOT of highway miles he had restaurants in St.Louis and Kansas City)
To Attention High mile owners
Old Jul 2, 2008 | 12:11 PM
toxdoc's Avatar
toxdoc
136K on my '99 C5. I drive it about half time as a DD. (But since it gets 23MPG combined, and my SUV 15MPG, I will probably drive the C5 more often now.)
Old Jul 2, 2008 | 02:42 PM
Keep up with the proper maintenance and keep on driving the car. It will last you a long time.
Old Jul 2, 2008 | 02:50 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
My '01 Z06 has 80,XXX on it and is more than fine, of course I've modded everything
The '98 I just picked up has 116,XXX and pulls hard, has great oil pressure, and no leaks. It's a repaired track rat so it does have a few quirks, but they're very robust cars.
Plus, like Steve said they're rather easy cars to work on and fix. You've got great resources like this forum where everything that can happen has happened and usually results in a how-to thread with pictures. You also have great sites like www.ls1howto.com that has tutorials with pics. I used that for my cam swap a few years ago.
