[Z06] Z06 Top Speed
Old Jul 1, 2008 | 08:58 PM
BillyTz06's Avatar
BillyTz06
Default Z06 Top Speed
What was the top speed of a 2002 Z06 rated at by the factory. Im making a sign board and need this information for it if any one knows.
Old Jul 1, 2008 | 09:15 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I believe the top speed is 171mph, and that is where redline in 5th gear occurs. It's a hard value derived from gearing ratios, though it could possibly vary a bit with differently sized tires and such. The car cannot pull in 6th hard enough to go faster than this. (as built from the factory, anyway)
Old Jul 1, 2008 | 11:34 PM
TGrits10's Avatar
TGrits10
Yeah 168 @ redline, 171 @ rev limiter. This was the cause of some confusion early on because journalists would report the top speed as either 168 or 171 and often fail to mention that it was gearing limited and not drag limited, leading to all sorts of wacky talk about FRC aerodynamics, gearing, powerbands, etc.
Old Jul 2, 2008 | 02:01 AM
ZeeOSix's Avatar
ZeeOSix
To add, at ~350 RWHP (which is what most stock 02+ C5Zs put down), the aerodynamic top speed would be 185 MPH. This means if it was geared perfectly, it would speed limit at 185 due to the aerodrag force balancing the wheel driving force.
Old Jul 2, 2008 | 07:45 AM
NVR KNO's Avatar
NVR KNO
^^^^ Hey.... My 01 Z put down 351rwhp.... Stock.
Old Jul 3, 2008 | 09:58 AM
The Wanderer's Avatar
The Wanderer
My 02 on the dyno at redline 5th gear speedo read 179 ... many in the past reported actual 5th gear road speed at 179 also.
I found this at http://www.corvettemuseum.com/specs/2002/testing.shtml
Top Speed Wide-Open Throttle
To simulate high-speed, autobahn conditions, Corvette is subjected to a wide-open throttle test on our five-mile circle track at the Milford Proving Grounds in Milford, Michigan. Starting with a full tank of gas, the car is driven flat-out at its 171-mph top speed until the fuel tank is empty - approximately 30 minutes. The test validates the car's ability to withstand extreme thermal loads reliably.
But it doesn't say if that was 5th or 6th gear. I believe it was 6th gear.
Last edited by The Wanderer; Jul 3, 2008 at 10:05 AM. Reason: adding additional info
Old Jul 3, 2008 | 11:40 AM
Cjunkie's Avatar
Cjunkie
If I remember correctly the 171mph top speed was for the 01 385hp Z06's I dont think there was a clear top speed for the 02-04 405 horse cars.
Old Jul 3, 2008 | 10:00 PM
BANDIT HPT's Avatar
BANDIT HPT
Some cool info you might like to know. When I was getting my car tuned, I found out the rev limiter in 5th gear is 9k rpms.
Old Jul 3, 2008 | 11:07 PM
thehammer69's Avatar
thehammer69
There are two rev limiters...one cuts fuel and the other closes the throttle. I like to refer to them as a hard and soft limiter. 5th gear is the only one set with the hard limiter at 9000rpm. Instead it uses the throttle limiter which is set to the same RPM hard limit as 1-4 & 6. The purpose to this is so you won't be running at top speed on a fuel cutting and stuttering hard limiter. Instead, the throttle starts closing down and you feel like you hit the aerodynamic wall. I have posted screen shots of these two tables in the past.
Old Jul 4, 2008 | 12:43 AM
ZeeOSix's Avatar
ZeeOSix
9K ... Your motor still in one piece?
Old Jul 4, 2008 | 12:47 AM
BANDIT HPT's Avatar
BANDIT HPT
Thats what it showed up as when we was tuning it.
Old Jul 4, 2008 | 01:07 AM
ZeeOSix's Avatar
ZeeOSix
So why would they set the rev-limiter to 9000 PRM when in reality it should never be allowed to rev anywhere near that high.
Also, I'm pretty sure the C5Z rev-limits out in 5th gear at 170-something, which is nowhere even close to 9000 PRM.
Old Jul 4, 2008 | 03:07 AM
PuJu Z's Avatar
PuJu Z
i tested mine out the second day i bought it. 171 on the way home from texas in 5th gear. now after the tune, exhaust, and taller tires...i don't have a clue. i guess it's time to go test it out
Old Jul 4, 2008 | 12:19 PM
thehammer69
Read my post above...
Old Jul 4, 2008 | 04:11 PM
ZeeOSix's Avatar
ZeeOSix
I did ... it's not very clear. Again, why would GM set the rev-limiter to 9000 when the engine would essentially self destruct if held there for very long. It's been said by one poster that his engine hit the 9K on the dyno.
Old Jul 4, 2008 | 06:13 PM
BANDIT HPT's Avatar
BANDIT HPT
Who hit 9k on the dyno? While tuning the car with HPTuners, you can see the factory settings for the rev limiter. For all the gears it was 6500 except for 5th gear. It was 9k rpms. What thehammer69 is saying is there is 2 sets or rev limiters. One cuts the fuel and the other cut the air (throttle). Instead of cutting fuel on a high speed run, it cuts off the air and doesn't give you a shutter like you do when you hit the rev limiter in other gears. Now if you hit the rev limiter in 6th gear… you got one bad *** car.
Old Jul 4, 2008 | 06:38 PM
ZeeOSix's Avatar
ZeeOSix
... I guess I mis-read your comment about 9K on the dyno. I see what you're saying.
To Z06 Top Speed
Old Jul 4, 2008 | 08:13 PM
PuJu Z's Avatar
PuJu Z
i wonder how fast you have to go to hit the rev limiter in 6th?
Old Jul 4, 2008 | 10:01 PM
ZeeOSix's Avatar
ZeeOSix
Gearing table says 259 MPH. Better be making at least 1000 RWHP to pull that one.
Old Jul 4, 2008 | 10:50 PM
thehammer69
They set it in the hard limit table to 9000rpm. In the ETC (electronic throttle control) table, it is set to the same limit as the other gears on the hard limiter. Therefore, it has a rev limiter, it's just a different type. Maybe I can find my old post as I don't have the screen shots of the two tables on this new laptop of mine.
