[Z06] Anyone lower with splash guards???
Old Jul 2, 2008 | 10:35 AM
BCBZ06's Avatar
BCBZ06
Default Anyone lower with splash guards???
I have read up on lowering and seen many pics that I love. I want to lower my car but I have the contoured splash guards on my car and would like some feedback. Anyone have any pics with these??? I love them for the track because they really save the lower side body panels from dings. But I'm not sure it would work with lowering the car if I'm going to constantly break them off.
Old Jul 2, 2008 | 11:48 AM
acrace's Avatar
acrace
I bought some thin black colored glass-reinforced polypropylene sheet material and cut out splash guards. On the rear I use on of the inner liner screws and a small binder clip to secure it. The front I use two inner liner screws. No holes drilled. I also use a Scotch clear guard as well on the lower fender/rockers. Trimmed it nicely and replace once a year. The contoured guards are really nice looking, but I wanted something "disposable". Good luck.
Old Jul 2, 2008 | 12:29 PM
BCBZ06's Avatar
BCBZ06
If you look at my profile there is a picture of the guards from the side. It's not the best picture to show this but it's mainly the front guards I'm worried about. I think the back ones will still have plenty of clearance if I lower the car.
Old Jul 3, 2008 | 08:58 AM
BCBZ06's Avatar
BCBZ06
Anyone???
Old Jul 3, 2008 | 10:22 PM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
I'm in the same boat. I've got a set of the contoured guards ready to install and I've already lowered my car. When I place the front guard on the fender it measures 3" from bottom of guard to the ground. I can't return them as they are painted to match my car. I've thought about triming an inch or so from the part of the guard that contacts the bottom of the fender, that would raise the whole guard up the same amount thats trimed off. Just wondering if any one else has done this?
Old Jul 4, 2008 | 06:40 PM
Russ K's Avatar
Russ K
My car is lowered on the stock bolts, and I have scraped the bottom of the front Altec splash guards.
I trimmed 5/8" from the part of the guard that touches the bottom of the fender & contoured the side of the guard to fit perfectly.
This gained ~ 1/2" ground clearance.
Russ Kemp
Old Jul 4, 2008 | 07:22 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
I bought large truck style plastic splash guards from Pepboys to use during HPDE's, costs about $15. They are wide enough to cover the width of the Z06 tires front and rear, and I use the existing screws to mount them...no drilling required. It takes about 15-20 minutes to put them on, and they come off even faster. I have the fronts mounted low enough to keep debris from kicking up, they actually scrape during hard cornering.
Old Jul 7, 2008 | 01:37 PM
BCBZ06's Avatar
BCBZ06
Russ Kemp
What did you use to trim the part that lines up with the car? It's a great idea, i'm just curious how you did it. My car is not lowered and I've already had to replace the one front side already due to scraping something.
Old Jul 7, 2008 | 01:45 PM
Russ K's Avatar
Russ K
I used a high speed dremel tool to get the contour close, then used a file to finish.
Russ Kemp
Old Jul 7, 2008 | 06:13 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
yes and I f'd them up bad already getting in and out of my driveway.
both are ground up on the bottoms, & cracked as well.
im going to raise the car 1/2" and then try those new aspsis ones that are suppose to be a little less low in profile and higher in teh wheel wells.
Also going to go 19/20 on tires instead of stocks.
Hopefully will not destroy another pair with these mods.
To Anyone lower with splash guards???
