I have noticed that the vanity lights in the visor and the light under the hood won't light. The bulbs appear to be good. Strange that both visor and hood light stopped together. What fuse should I check for these. Don't seem to be anything other than those that don't work. Can someone help please.
Hi There,
Check the #2 fuse located in the passenger foot well. It is probably blown out.This fuse controls the vanity lights.Change the under hood light bulb & follow the wire & make sure your connector is free from corrosion, plugged in & secure.If the hood light is still inop. then your visors are probably are unplugged or loose.
Have a nice 4th of july
robsc501
Hi Bob,
Your welcome.Glad to hear you found the fuse problem.Raining on & off all day here. High temp. of 72 degrees. Looks like the same forecast for the entire weekend. Any way have a good weekend.
Rob
robsc501
