Difficulty
Old Jul 6, 2008 | 07:40 PM
slverc5's Avatar
slverc5
Default Difficulty
I've been eyeing a couple of C6 Z51 shocks that's on sale at the parts 4 sale section I didn't pull the trigger yet because I didn't want to buy them if I won't be able to install them DIY. I installed my own sway bars and those are pretty simple. Now my question is. How hard are the shocks to install? And what's the ft/lbs of torque that I would need to tighten them. I got the tools just making sure I know the figures. Yes I did a search and it showed a lot of results which I kind off browsed thru and didn't find anything of what I'm about to do. A sticky would help greatly. Thanks!
Old Jul 6, 2008 | 07:46 PM
MagRedConv's Avatar
MagRedConv
http://redshift.homestead.com/files/C5torque.PDF
Old Jul 6, 2008 | 07:53 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
It's a 3 out of 5 IMO. If you have 2 ppl --- it's easier.
I found the hardest part was compressing the shocks to remove/install --- other than that it was pretty straight forward.
.02¢ deposited
Old Jul 6, 2008 | 07:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's a joke to install shocks. Should take ya a couple of hours on jackstands taking your time.
Old Jul 6, 2008 | 08:16 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
Shocks are easy money. Couple beers and an hour or two and you'll be done.
Old Jul 6, 2008 | 09:43 PM
crignaj's Avatar
crignaj
Just use tye wraps to keep the shocks compressed & they will just fall out after unbolting. If you can swap sway bars, you can swap shocks
Old Jul 6, 2008 | 11:00 PM
slverc5's Avatar
slverc5
Thanks for the tips. Now all I need the the proper torque numbers. will look at the link above.
To Difficulty
