!!Windshield fuild pump!!1
Old Jul 7, 2008 | 01:10 AM
NicksZ06's Avatar
NicksZ06
Default !!Windshield fluid pump!!
Hello
I have just recently noticed that my windshield wiper pump isnt working anymore. Ok yes there is fluid in it and no the pump is not operating. I thought easy fix fuse and i have looked and havent noticed a blown fuse. Next step replaced the pump. No dice. Now the windshield wipers move when i push the button so i know the switch is working. Bought a voltage tester and no power. The fluid tank is also not working and they are on the same wiring harness. So this led me to wiring or fuses again. The wiring appears to be going into the ABS module and then into the fuse box. There is a little canister plug that the harness plugs into on the ABS module.
Does what that is called and does anyone know which fuse it is in the fuse box. I am lost. I see nothing that says windshield fluid pump in there.
Any help would be awesome.
Old Jul 7, 2008 | 01:30 AM
NicksZ06's Avatar
NicksZ06
I cant spell
Fluid!!!!
Old Jul 7, 2008 | 10:06 AM
mhorton01's Avatar
mhorton01
You can check this short thread for the whole story of what happened to me (post #8 explains the symptoms), but the problem ultimately ended up being a "floating ground" issue, which required me to ground the fluid pump directly to it's own ground...
http://forums.corvetteforum.com/show...ight=mhorton01
Good luck!
To !!Windshield fuild pump!!1
