Yep 4 quarts will do ya!! Try Royal Purple Syncro Max You'll love the results!! While you're at it Take a basting syringe and suck out the clutch master cylinder and refill with Dot 3 or 4 brake fluid!!
Took about 3.5 quarts when I changed mine... just depends on how much you can get out. The puddle on the garage floor and/or transmission fluid dripping down your arm will make it pretty obvious that it's had enough
