Will My Tires Fit?
Old Jul 8, 2008 | 11:48 PM
98blackonblack's Avatar
98blackonblack
Default Will My Tires Fit?
I have a 98 with the stock wagon wheels, I have 245-45-17 and 275-40-18 tires, I found a set of black c5 z06 rims for a good price, will my tires fit?
Old Jul 9, 2008 | 08:18 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
You didn't say if the black Z06 wheels are the factory 9.5" front and 10.5" rear Z06 wheel width, which are a inch wider than your stock wagon wheels.
Your tires will probably mount on the wheels,but the sidewalls will appear somewhat stretched. I wouldn't recommend it.
Old Jul 9, 2008 | 12:20 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Does Not Fit
Old Jul 9, 2008 | 04:58 PM
Russ K's Avatar
Russ K
The tires will fit, but will be stretched as mentioned. But once the tires wear out, install 265/40/17 & 295/35/18 sizes.
Russ Kemp
Old Jul 9, 2008 | 05:10 PM
Crab's Avatar
Crab
I agree with Russ K. IF the Z06 wheels are 9.5 inch the 245/45/17 will fit, but they(tire) will look horrible. The wheel will spread the sidewall farther apart than they are designed to be( ask me how I know), it may be safe......but I would'nt do it. Same with the rear. You did'nt say if these wheels were GM Z06 wheels or replica aftermarket. Your stock wagon wheels are 8.5 front and 9.5 rear. I belive Z06 wheels are 9.5 front 10.5 rear
Old Jul 9, 2008 | 05:23 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
According to Goodyear,your fronts can fit on up to 9" and your rears on up to 11". The 245s won't be dangerous on 9.5"s,and I wouldn't hesitate to use them up and then get some real tires.
To Will My Tires Fit?
