Hvac Actuator Problem Help!!!
I need help!!! I have the drivers side actuator problem on my 98. I have the two codes B0361 and B0441. I have replaced the head unit, charged the freon in the system, tried pulling #27 fuse, and I just replaced the drivers side actuator last night and I still have a problem. After installing the new actuator the codes have changed a little. With the A/C off the only code that comes up is B03661 H C but when I turn the A/C on I get codes B0361 H and B0441 H C. Then I hit reset and I get B0361 H and B0441 H and I still get warm air on the drivers side and cold on the passengers. Can anyone tell me what else could be the problem??? Can I possibly have gotten a bad actuator? PLEASE HELP!!!!!!!!!!!
B0361 is a short to ground code, B0441 is an out of range code. You may need to check for a pinched, or chafed wire, or corroded connector which can also give you the B0361 code.
