What's normal?
Old Jul 16, 2008 | 12:59 AM
Z28Johnny's Avatar
Z28Johnny
Default What's normal?
So my "low engine oil" message came on today. I stopped by Jiffy Lube, which is where the previous owner had taken it. They filled it up for free because it wasn't quite time for a full change.
It took about a quart and a half. Is this normal? The sticker and computer where not entered correctly so I don't know exactly how many miles have put on since the last change, but I believe it is between 3,000 and 4,000 miles.
I read that the 00 and 01's had oil burning issues, mine is an 02. There is no oil to speak of leaking onto my garage floor. I just want to be sure that if it isn't normal, I do what I need to to have it fixed. If it is normal, then I'll be making a trip to Jiffy Lube to get free oil every once in a while
John
Old Jul 16, 2008 | 01:02 AM
Z28Johnny's Avatar
Z28Johnny
It was kind of cool, they topped off my windshield wiper fluid too. I didn't pay to have the original change done there, the previous owner did.
Now I just need to find a gas station with the same kind of service. You know to top off my tank every once in a while for FREE. Almost everything is better when it is free
Old Jul 16, 2008 | 01:47 AM
94-vette's Avatar
94-vette
Did you park on a steep incline?
Old Jul 16, 2008 | 02:24 AM
CamachoSF's Avatar
CamachoSF
I have the same issue in my 02. I read that if you really get on it a lot, it will burn more oil. After about 1000-1200 miles of a fresh oil change, the low oil light will come on. The kicker is, i rarely get the RPM above 4000, only when getting on the highway. I rarely get on the highway....
Old Jul 16, 2008 | 07:43 AM
kww's Avatar
kww
My '00 doesn't use a drop of oil between changes even with the install of the ECS supercharger. (has almost 41,000) I change my own oil so I know the level is right. Did you check to be sure Jiffy Lube put the correct amount of oil in when they changed it?
Old Jul 16, 2008 | 08:02 AM
Some oil may be used between oil changes, but IMO should not be in the quart/quart and a half range with that number of miles. Only exception may be if you really run the car hard. Otherwise, might be a good idea to keep a watch on it. Perhaps they place did not put in the right amount when they did the last change.
Old Jul 16, 2008 | 10:36 AM
Z28Johnny's Avatar
Z28Johnny
I don't run it really hard. I use it for a daily drive, but I definitely get on it on a daily basis. This car is what inspires me to drive my butt to work every day
I guess now that I know it is at the proper level, I'll keep an eye on it and see what's up.
Thank you,
John
Old Jul 16, 2008 | 10:43 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Thank you,
John
Mine's a daily drive too. Mine does not use any oil. Bought it last Oct with 25K miles and it has 44K miles now.
Old Jul 16, 2008 | 11:14 AM
bhoch's Avatar
bhoch
A few weeks after I first purchased my car (August last year) I had the same issue. I put a little over 1 quart in and the light went out. Car had 29K on it when I purchased it. It now has 48K on it and that is the ONLY time it's ever used any oil. Apparently, I'm not capable of reading a dipstick (or I am one) as I did not see that the oil was low while checking it in my garage. I have had 3 Oil changes since I purchased the car and other then just a few days after first purchase, it has not needed any oil between changes and that light has not come on again, either.
Mine is a '00 coupe.
I would say just monitor it for a few weeks )4-6); checking the oil level weekly and go from there. Unless it's just burning it, could have just been low when purchased.
Old Jul 16, 2008 | 12:11 PM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
I had the same issue with mine. Switched to Royal Purple and problem solved.
Old Jul 16, 2008 | 02:50 PM
MURPHY55347's Avatar
MURPHY55347
Maybe they screwed up initailly and only put in 5 quarts instead of the 6.5 required???
Old Jul 16, 2008 | 03:05 PM
Fly-N-LOw's Avatar
Fly-N-LOw
More like probably,think about it what kind of meatball works the pit at Jiffy Lube
Old Jul 16, 2008 | 03:43 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I've got a 00-Coupe, 48k miles and I've never had an oil issue either, no runs, no leaks, no drips, no burning of oil, and I do a WOT on her every now and than. Maybe you were shorted at the oil change?
Old Jul 16, 2008 | 03:52 PM
CamachoSF's Avatar
CamachoSF
That is a good possibility, thing is, i took it to the dealer that i bought it from. They have about 7 or 8 vettes in the lot and in the showroom. I would think they know a thing or two about vettes. Maybe a new technician?
Old Jul 16, 2008 | 06:39 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Did Jiffy Lube top off the oil with Mobil 1 or something else?
Old Jul 16, 2008 | 09:13 PM
Dominic Toretto's Avatar
Dominic Toretto
That's especially true about women
-Alex
Old Jul 16, 2008 | 10:02 PM
DaBoz's Avatar
DaBoz
-Alex
You get what you pay for!!
To What's normal?
Old Jul 16, 2008 | 11:26 PM
homewrecker's Avatar
homewrecker
I got 3 words...Royal Purple..okay that was 2.
Why, if I may - are you taking it to Jiffy Lube? They probably put the wrong amount of oil in your baby. I think you should change the oil yourself.
Old Jul 17, 2008 | 01:53 AM
JustinStrife's Avatar
JustinStrife
My 01' has a tendency to burn oil when you beat on it.
My 00' doesn't though.
Old Jul 19, 2008 | 09:07 AM
Z28Johnny's Avatar
Z28Johnny
I took it there mostly to get info from the previous change that was done by the previous owner. They did put the nicer Mobil stuff in. I think the first Jiffy Lube probably didn't fill it all of the way, they couldn't even type the mileage correctly into the computer.
I'm not afraid to do changes myself, but as for putting it in the hands of others... It all depends on the people. You could have the best dealership in the country do it, but it could be the new guy or the guy who it's his last day and doesn't care. You could go to some hole in the ground dive and get some perfectionist that loves your car as much as you. Good and bad service can come from anywhere.
