[Z06] C6Z shifter Install...Please Help
Old Jul 17, 2008 | 05:41 PM
dkny_stylez's Avatar
dkny_stylez
Default C6Z shifter Install...Please Help
I'm having a problem with the neutral adjusting pin, i'm reading the writeup, and he says he just pulled it up, this thing seems like its stuck?
Any suggestions?
Old Jul 17, 2008 | 05:46 PM
hotwheels57's Avatar
hotwheels57
I'm confused...are you referring to removing it from the storage position on the front of the oem shifter or removing it once you're done using it for the neutral alignment?
Old Jul 17, 2008 | 05:49 PM
dkny_stylez
I got the whole c6z shifter assembly in, near the front there's that pin, you have to pull up to free the shifter movement. I jsut can't move it up
Old Jul 17, 2008 | 06:02 PM
hotwheels57
I'm still confused...did you remove the alignment pin from the storage position slot on the front of the shifter and place it into the alignment hole during the R&R installation?
The pin usually has some knurling on it which helps keep it secure in the storage position slot on the front of the oem shifter.
If you never used it during the installation, then you've already gone past the need for it.
Old Jul 17, 2008 | 06:11 PM
hotwheels57
Not knowing what you read to prepare yourself for the installation, try reading this post by member patches complete with images.
http://forums.corvetteforum.com/show....php?t=1022661
If the pin is so tight (assuming you actually used it for the installation to maintain neutral) that you can't remove it, it could be preloaded/jammed. You might need to loosen the four 1/4-20 mounting bolts slightly until the pin can be moved up and down freely. Then snug the mounting bolts back down to the correct torque and remove the pin.
Old Jul 17, 2008 | 06:18 PM
dkny_stylez
thanks for the help, i managed to pop it up with a screw driver, now i'm jsut tackling the shift boot, so it will fit properly.
Old Jul 17, 2008 | 06:32 PM
hotwheels57
Old Jul 18, 2008 | 01:56 AM
dieseldave56's Avatar
dieseldave56
Default I see problems...............
hotwheels57 is correct with the statement concerning the alignment pin having to be free when pulling it up. You may experience shifting problems. I've done three and adjusted for a free and easy pin retraction. Cross my fingers for ya.
To C6Z shifter Install...Please Help
