Traction control warning light
Old Jul 18, 2008 | 07:58 AM
John Salva's Avatar
John Salva
Cruising
Default Traction control warning light
Every so often the traction control service soon warning comes on. This only occurs just after starting the engine. Sometime after driving about 1 mile. Shutting the engine off and removing the key resets the light and it does not come back on for several days again. Any ideas? 2001 vette
Old Jul 18, 2008 | 08:11 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I have seen that on mine as well , I think its not much to worry about ,I think.
Old Jul 18, 2008 | 08:27 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Pull your codes via the DIC. It will have "H" History codes as well as "C" Current codes. Once you have the codes it's relatively easy to tell if you have a problem reocurring to cause the problem
Old Jul 18, 2008 | 08:34 AM
mojo1's Avatar
mojo1
Hope you are having a fun time in Florida!
To Traction control warning light
