Tire size experts????
Jul 18, 2008 | 12:55 PM
St. Jude Donor '06 thru '15, '19
I have put new wheels on my car 18 all around and have traction control problems
Front = 275/40/ 18 , wheels are 9.5
Rear = 295/35/18 wheels are 10.5
trac comes on because the backs are smaller than front , it looks like I have to go to 225/40/18 on the fronts to correct this , is this right?
http://forums.corvetteforum.com/show....php?t=2066960
Jul 18, 2008 | 01:00 PM
St. Jude Donor '08
Get yourself a 275/35/18. This will make the front smaller than the rear by about .4 inches.
When you go with the 275/40/18 your front is about .4 inches taller than the rear, which is bad.
Here is a link to show what I mean.
http://www.tirerack.com/tires/Spec.j...num%3D74YR8EMX
Hope that helps.
Jul 18, 2008 | 01:04 PM
St. Jude Donor '08
Quote:
Originally Posted by
Independent1
Hope that helps.
http://www.discounttire.com/dtcs/infoTireMath.dos
I would use this calculator to get your new tires the same diameter as the originals
Jul 18, 2008 | 01:23 PM
I belive that with a programmer you can change the wheel sizes.
But, you need something like the Diablo
Jul 18, 2008 | 01:27 PM
Would rather change the fronts, they are cheap tires and the backs are brand new. I used a calculator and to get the difference the same as stock, it was 225 , (1" differnce) , How close to that do I need to be to do away with the problem. And thanks a ton for the help.
Jul 18, 2008 | 01:35 PM
Install 265/35/18 tires on the front.
Russ Kemp
Jul 18, 2008 | 01:49 PM
Russ K
Russ Kemp
Thanks , I will . This tire math just will not sink into my old thick scull!
Jul 18, 2008 | 05:52 PM
Cruise-In IX Veteran
front should be a 35, I run factory 18x9.5 all the way around. 275/35/18 and 275/40/189, no problems!
