[Z06] First time at the strip
Old Jul 18, 2008 | 04:53 PM
kbdub's Avatar
kbdub
Default First time at the strip
Took 5 passes last night in 100 degree weather and a smoking hot track. Part bad conditions and first time at track jitters gave me less than I wanted. Hopefully these times go down dramatically next time I make it out. I launched around 2200-2500 with slight tire squeal each time. Spun 1st-2nd most times even though I told myself to ease in on the gas...iin the heat of action I must have still nailed it. I'm running on Vredesteins. Any feedback is appreciated.
Reaction 1.505
60 2.2091
330 5.7811
1/8 ET 8.5991
1/8 MPH 88.37
1/4 ET 13.011
1/4MPH 110.27
Old Jul 18, 2008 | 04:59 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Originally Posted by kbdub
Took 5 passes last night in 100 degree weather and a smoking hot track. The car was above 215 F on every pass. Part bad conditions and first time at track jitters gave me less than I wanted. Hopefully these times go down dramatically next time I make it out. The second pass I didn't make 3rd and put it in 4th and coasted. I launched around 2200-2500 with slight tire squeal each time. Spun 1st-2nd most times even though I told myself to ease in on the gas...iin the heat of action I must have still nailed it. I'm running on Vredesteins. Any feedback is appreciated.
Reaction 1.505
60 2.2091
330 5.7811
1/8 ET 8.5991
1/8 MPH 88.37
1/4 ET 13.011
1/4MPH 110.27
Not bad runs for the heat! Get the 60' down 2 tenths and you will be running 12.60's.
Old Jul 18, 2008 | 05:07 PM
kbdub's Avatar
kbdub
I was really hoping that I just needed to work on the 60'. If that takes 1/2 second off I'll be I was mad I didn't get below 13, but I thought it was partly due to the heat and to the 60'.
Old Jul 18, 2008 | 06:50 PM
pit-man's Avatar
pit-man
Those aren't bad at all for 100 degree heat and the terrible 60 foot (sorry). I have tracked the difference...85 degree air to 49 degree air was 2.5 tenths for me. My buddy had a Trans Am... we both ran on the same days and both of our times dropped the same amount. With a better sixty foot and cold air..you are12.3-12.5 at least. Keep at it
Pitt
Old Jul 18, 2008 | 07:08 PM
Savior1974's Avatar
Savior1974
Yeah, dont feel bad. My best run my first time out was a 13.02 with a 2.4 60ft in Fontana Ca (100+ day also).
Old Jul 18, 2008 | 07:31 PM
TM-Z06's Avatar
TM-Z06
My first run was in 95 degree weather and I ran a 13.01@116 with a 2.3 60'
Don't worry, it gets better as you gain more experience.
Old Jul 19, 2008 | 03:02 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
My first runs were also in the 12s and 13s, lol. Once i got a set of Drag radials, on my 5th pass the time in my Sig was had. So no worry, just get some practice in and use ranger's launch write up, as that's what I used for my Sig run, it works and that run still hold 7th place in the Fast list in sticky. there is a lot of info and insight that can be had from many by ready the sticky above on driving to fast ETs. good Luck
Robert
To First time at the strip
