Checking Resistance on Plug Wires
Old Jul 19, 2008 | 12:22 PM
Tigershark3's Avatar
Tigershark3
Default Checking Resistance on Plug Wires
Has anyone ever done it? I'm getting a .38 reading so there is some resistance there. Anyone know what a normal reading should be? I've got the GM performance wires.
Old Jul 19, 2008 | 12:52 PM
Bakersfield's Avatar
Bakersfield
I would say if you test the others wires and they read the same amount of ohms, then that would be a normal reading. If not, it could mean some corrosion is creeping into the wires.
Old Jul 19, 2008 | 02:35 PM
2KFRC5's Avatar
2KFRC5
Don't know about the red wires, but as a reference point, the service manual says to replace the OEM wires if they have a reading over 700 ohms.
Old Jul 19, 2008 | 04:07 PM
Tigershark3
Thanks. When my meter is set on the 2000 setting all my wires read 375.
Old Jul 19, 2008 | 05:14 PM
Buckskiner's Avatar
Buckskiner
Default good
they good
Old Jul 21, 2008 | 10:21 PM
docohm's Avatar
docohm
I tested all mine when I changed plugs a couple of years ago, they are the stock wires and all read between 370 and 380 ohms. So, it sounds like yours are OK too.
Have fun...
DocOhm
To Checking Resistance on Plug Wires
