P0171 and P0174
Old Jul 20, 2008 | 04:49 PM
NEVERL8C5's Avatar
NEVERL8C5
Default P0171 and P0174
Have a friend with these codes P0171 and P0174 bank 1 and 2 too lean.
Does anyone have any ideas? The car is also exhibiting a slight pulsing rise and drop in RPM's at idle.
Old Jul 20, 2008 | 04:54 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Default I'm not a mechanic but,,
It sounds like clogged injectors to me.
Old Jul 20, 2008 | 05:02 PM
c5streak's Avatar
c5streak
Have you checked all of the intake piping for a vacuum leak. Or an exhaust leak before the O2 sensor.
Old Jul 20, 2008 | 07:22 PM
Milan's Avatar
Milan
What mods are done to the car? If it's not stock it probably needs a tune.
Old Jul 20, 2008 | 07:24 PM
SilverBullit02's Avatar
SilverBullit02
I had the exact same thing this spring. It was a vaccuum leak at the throttle body. Passenger side, just above the rocker cover (under the fuel rail cover) PCV hose had a hole in it at a 90 degree bend. GM wanted $400.00 for the "hose assembly" (they have been known to go bad) I fixed it for $2.00 with a piece of 3/8 neoprene fuel hose in 30 seconds. good luck.
Old Jul 20, 2008 | 08:44 PM
ssdeuce's Avatar
ssdeuce
I get the same codes after installing the Vararam kit. I'm about to install American racing headers and get a tune.
Old Jul 20, 2008 | 09:59 PM
i2oyal i2ed's Avatar
i2oyal i2ed
Its the exact thing that happened to me after the Vararam install, arh headers AND tune. I had to go back to get it retuned.
Old Jul 20, 2008 | 10:03 PM
NEVERL8C5's Avatar
NEVERL8C5
This is a bone stock 2001 no mods at all not even fuzzy dice.I will look for the things mentioned and see if I can solve the issue.Thanks
Old Jul 20, 2008 | 10:15 PM
CrVetteteK's Avatar
CrVetteteK
I agree with the vacuum leak. Use a can of carb cleaner and lightly spray around the base of the intake. that may reveal any vacuum leaks.
Thats where Id start. If its runing rough, I know GM has a bullitin out for those codes plus a p0300 for bad bank 1 o2 sensors.
Hope that helps.
~CRV
Old Jul 25, 2008 | 11:45 PM
NEVERL8C5's Avatar
NEVERL8C5
Just to let everyone know the carb spray located a leak in the intake gasket right in front. This is being replaced on Monday.I am also having the manifold checked for warpage.
Old Jul 26, 2008 | 03:22 AM
CrVetteteK's Avatar
CrVetteteK
Cool! Glad you found it! I know theres a bullitin for the trucks for manifold warpage - havent seen one for the cars - yet.
Im sure it will be fine - probably bad gaskets.
Keep us posted!
~CRV
To P0171 and P0174
