[Z06] Does a bigger Throttle body work?
Old Dec 28, 2001 | 08:43 PM
Pio's Avatar
Pio
Default Does a bigger Throttle body work?
Hi-
Wondering if you have any experience with bigger or ported TB's on the Z06.
I'm hesitant to port mine or purchase a bigger one from a supporting vendor because I installed a bigger TB on my old 98 and it didn't work well.
Thanks for your help.
Old Dec 29, 2001 | 12:38 AM
ZO6LS6's Avatar
ZO6LS6
Default Re: Does a bigger Throttle body work? (Pio)
Pio, you don't need a larger one, unless you are going to mod it out to the max..........your '01 will work fine all the way past 400rwhp.........
It would probably HURT your performance..............and for sure cost you $$$$$$$ :yesnod:
Old Dec 29, 2001 | 02:48 AM
jrd's Avatar
jrd
If you install bigger TB you then need more fuel. If you adjust for more fuel you then should reprogram the computer. Not worth the expense and effort unless you have internal Mods like heads, cam etc...
Old Dec 29, 2001 | 03:17 AM
FRC Tom's Avatar
FRC Tom
NO
Old Dec 29, 2001 | 04:02 AM
Mako's Avatar
Mako
No difference on my 427 on the dyno and a loss of throttle response--ask Phantom 1000 too as he tried both on his 385.
Old Dec 29, 2001 | 12:35 PM
Pio's Avatar
Pio
Default Re: Does a bigger Throttle body work? (Mako)
Thanks guys. I thought so.
Old Dec 30, 2001 | 12:53 PM
Phantom1000's Avatar
Phantom1000
To Does a bigger Throttle body work?
