Will it work
Old Jul 21, 2008 | 09:35 PM
Dave concrete's Avatar
Dave concrete
Default Will it work
Will the manuel from a C6Z fit or work in a C5Z
Old Jul 21, 2008 | 09:37 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
are you talking about the shifter or the transmission.
Shifter yes
Trans no
Peace
Chip
__________________
..................Click for
Old Jul 21, 2008 | 10:00 PM
Dave concrete
Trans I was talking about.If it don't fit how much different are the gears. I find it awsome to have a 60mph pull in 1st.I know it is also because of the 7000 rpm but that can't be the only reason.
Old Jul 21, 2008 | 11:08 PM
warpster's Avatar
warpster
Sure, you can put any manual you want in the glove box (as long as it fits)
Old Jul 21, 2008 | 11:15 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
The trans mainshaft is different as is the differential (larger ring gear). You can have a trans custom re-built with taller gearing if thats what you want. Talk to Rodney at RPMtransmissions.
To Will it work
