I was looking at getting some NT55R tires for my Z for the front i was going to put 275/40R17 and in the rear 305/45R18.... does this sound good? anyone have the same setup with pics? and what kind of acceleration change would i notice over stock tires? thanks
Fronts should be fine, the rears are much taller than stock, it will reduce your rear end ratio numerically, not sure if they will fit might be too tall. it will make your acceleration slower.
I have the NT555 R2's. 275/40/17 & 305/35/18. The car grips alot better then the stock F1's. Only downside is the front sidewall is a bit taller than the rear.
i have 305/45/18s in the back and i had to pull out the brake duct and also the inner fender liner. took all of 15 minutes. front tires are fuzion 275's
I just installed a set of the RIIs. They stick much better than the stock F1 Supercars. I never really knew what 1st gear felt like until I got these tires. I would stick with the 305/35/18s on the rear. They will look better and not require chnages to get them to fit.
I have the 275/40 in the front and 305/35 in the rear in the Nitto's. i absolutly love this set up. Great handing on street and track and much better over the F1's. My rear set will need replacing this fall and i will certainly get another set. price is good too.
Thanks for all the info and the pics look great!!! I cant wait! I am going to go with the 35's since i really dont want to remove anything from the car..... thanks for the help guys!
yeah i ordered 35s but discounttiredirect.com sent me the wrong tires so put them on anyway and thought that it filled out the wheel wells nicely so i kept them
