1999 corvette battery problem
Old Jul 23, 2008 | 06:23 PM
skip5546's Avatar
skip5546
4th Gear
Default 1999 corvette battery problem
My 1999 corvette battery discharges and will not start if left for as little as 2 days. I have changed the battery and the problem remains. Any ideas where to look for the problem.
Old Jul 23, 2008 | 06:28 PM
c3_enthusiast's Avatar
c3_enthusiast
you obviously checked to make sure all accessories are off? map lights, trunk deck closed, hood lamp off, parking lights?
Do you have an aftermarket audio system?
Old Jul 23, 2008 | 07:09 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
How old is the battery? Sounds to me like it's going Tango Uniform....
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
need to check for a parasitic draw. at rest there shouldn't more than a few milliamps
Old Jul 23, 2008 | 09:39 PM
skip5546's Avatar
skip5546
4th Gear
this battery is 3 months old. I cleaned the grounds and tightened the bettery connections. Nothing left on.
Old Jul 23, 2008 | 09:41 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Vermin in the wiring perhaps?
skip5546's Avatar
skip5546
4th Gear
We did that and the draw is not 30ma but 200ma. Just can not find what is drawing the power. Any ideas?
Old Jul 24, 2008 | 03:13 PM
poolboy's Avatar
poolboy
yes, but it may take some time. What you'll need to do is to start pulling fuses (one at a time) until you find one (or maybe more) that is causing the draw. Then, of course, you'll need to trace that fuse to see where the problem is.
Old Jul 24, 2008 | 03:24 PM
tony car4a's Avatar
tony car4a
Just a thought... I'm guessing the hood is open while you're checking, so if you have the under hood lamp you may want to remove the bulb.
Old Jul 24, 2008 | 03:34 PM
10U 99's Avatar
10U 99
I had a similar situation, it was the bolster switch on the drivers seat
Old Jul 24, 2008 | 04:03 PM
Perhaps you have a component that is not completely shutting down and is draining the battery. Might want to get it checked by a good mechanic.
To 1999 corvette battery problem
