Head light did not pop up
Old Jul 25, 2008 | 09:23 PM
ter's Avatar
ter
Default Head light did not pop up
My passenger side head light did not pop up tonight on two attempts. It did pop on the third try, and it tested good about 10 times. It has 40,000 miles. Was this just a freak thing, or do the gears go bad that early?
Where is a good place to buy the gears and instructions?
Thanks.
Old Jul 25, 2008 | 09:39 PM
pikerunner's Avatar
pikerunner
The original gear is plastic. Rebuild kits and how to's can be found on the forum, just do a search. My 2000 lasted 70k before starting to make a loud noise.
Got mine from rodneydickman.com. I decided to go ahead and get the pair. It is good kit but took me awhile to figure out how to get the headlight assembly out the first time.
Cost is about $90 for the pair. It sure beats the dealership price for new at north of $200.
Good luck.
Old Jul 25, 2008 | 10:12 PM
Kale's Avatar
Kale
Get the t brace.
Old Jul 25, 2008 | 11:29 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Good luck.
Rodney's kit,,,,and you are good to go! Change out both sides,,,,end of problem!
Old Aug 4, 2008 | 09:10 PM
robsc501's Avatar
robsc501
Hi There,
Check this: outwww.bfranker.badz28.com/headlightfix/gearinstall.wmv or
www.corvetteaction center.com/tech/howto/idx,php/50/0181/article
robsc501
Old Aug 4, 2008 | 10:06 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Originally Posted by robsc501
Hi There,
robsc501
You may want to delete this post...I dont think the Mods will like another forum site here.......................
Old Aug 5, 2008 | 12:51 AM
Mixxit's Avatar
Mixxit
I have done the gear replacement and sometimes mine still doesn't pop up. If I open the hood and give it a twist or 2 on the manual open/close ****, it opens just fine. It's almost like it goes down too far and can't get itself back open unless I get it started manually. Weird huh?
Old Aug 5, 2008 | 09:06 AM
evil frc's Avatar
evil frc
mine did the same thing this weekend. no sound at all from the pass side motor. I did a search and am going to check the grounds behind the headlight and then the control module.
Keep us updated
Old Aug 5, 2008 | 10:16 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Keep us updated
There are a couple of usual causes to headlamp problems. The gears of course but you will hear the motor. Another is if the lamps don't turn on at all (no illumination), then check or cycle the headlamp switch as they tend to go bad. Next is if the headlamps turn on, but don't rise...that's usually the headlamp control module located at the right forward frame rail.
Old Aug 5, 2008 | 12:26 PM
FiZzd's Avatar
FiZzd
Hope this helps:
http://cgi.ebay.com/ebaymotors/97-04...mZ380052278118
http://cgi.ebay.com/ebaymotors/ws/eB...071177137&rd=1
To Head light did not pop up
