Headers
Tune
Vararam Intake
Gears (wont' give you hp, but you will feel like it does)
Turbos
Roller Rockers
Larger/Better Intake and thottlebody (FAST, Ported LS6)
Keep in mind, just as I learned from my post. HP gainers are different from car to car. 1 guy might get 5 hp from porting his throttlebody vs another guy will get nothing. It works like this across the border. I think to make your thread more fair and give actual results, your going to have to give your baseline engine setup. Are you talking about starting stock and trying to increase HP or are you talking about a car that has already had some stuff done to it. As mentioned, HP is relative to the combination you use and what amount of money you want to spend. Oh one more big thing. Keep in mind increasing HP is only a small percent of the battle.
1. Once you increase HP enough you will have to.....
A. Get a tune.... ($500 and up)
B. Get a new clutch to handle the new HP ($500 and up)
C. Upgrade other systems such as suspension and tranny if the HP proves to powerful for them ($1000 and up)
Its really as many have mentioned...a never ending catch. Once you get the HP bug you really have to control yourself or you will find yourself broke in the wallet as well as a broken car.
As I have heard over and over again. Find out what your goals are, find out exactly everything involved, keep in mind all the repercussions your going to create by what your about to do to your car, and most of all make sure you have plenty of money to cover everything plus some.
I agree with most of this based on my limited experience. However I would also add any true CAI (vararam is one of them) and I would put cam, heads, heads and cam ahead of better intake and throttle body. If you have an LS6 intake, you probably won't need a Fast or such till you add heads and cam. Forced induction Turbos, superchargers) should obviously be on the list but majority of folks will do the other things 1st. Just my .02.
Headers
Tune
Vararam Intake
Turbos
Roller Rockers
I noticed a very good increase in power when I installed a set of Borla Stingers.
I also noticed a difference when I installed new Bosch fusion plugs.
(this may not be the fact that the new plugs were better than other new plugs as much as they were better than the worn out ones I removed)
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Forget the little stuff. If you are into modding you might as well start at or near the top. I ebayed all the little stuff off this winter after I realized a big blower was the way that I really wanted to go all along. There's nothing like a nice, big FI setup. You can't light them up at 60 MPH with only a CAI and Borlas. http://temp.corvetteforum.net/c5/esc...//drivings.gif
Yes ANY CAI will let more air in than the stock intake. However, at the stock HP level the bump in HP is not very high and motor get all the air it needs for THAT power level.
I view CAIs as a first step to something bigger or in conjunction with mods that will require more air. No doubt, a CAI will give you a HP bump and some of the better ones will give you a slightly bigger bump than that. Sorry for my lack of clarity
But it is an increase in HP. That's the thread question. Now if we're talking 500+ rwhp, for sure FI.
I don't recall if a dyno tune was mentioned but I gained 29 rwhp in three hours - $350. Stock car (at that time) btw with the exception of a K&N filter, X pipe, and Corsa Pace Car.
We are in agreement. I think a CAI with a tune is essential. CAIs indeed increase HP just not to the extent that some people (not you) claim
