in my valve stem?
Old Jul 28, 2008 | 02:27 PM
talon104's Avatar
talon104
Default in my valve stem?
Hey all, got a shock the other Day . My pressures weere reading a little low especially my right rear tire.So, i stopped to even them out and guess what? there is something in my right rear valve stem and it wont let me add any air .Almost like a O' ring or something sticking out around the valve part in the stem. Any idea what this is?
Chris
Old Jul 28, 2008 | 02:31 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Yes, I had the same thing happen on all four wheels. It is the o-ring from the top of your valve stem caps. Just pry it out with the tip of a knife or other sharp tool and you're good to go.
Old Jul 28, 2008 | 02:39 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Had the same thing with mine. Could not get a drop of air into it. Lil O Ring. Pulled it out with a bent paper clip and was good to go.
Old Jul 28, 2008 | 02:40 PM
talon104's Avatar
talon104
Thanks duckvett scared the whoowhoo, out of me thinking that the pressure sensor was gonna have a o' ring blow out and it would be sitting on the ground.
Thanks again for the quick response
Chris
Old Jul 28, 2008 | 02:42 PM
4 KRUSIN's Avatar
4 KRUSIN
Yep, been there, done that!
talon104's Avatar
talon104
Will do Benpup! Thanks for the help.
Chris
Old Jul 28, 2008 | 02:51 PM
talon104's Avatar
talon104
Problem solved It popped right out .
Thanks again everyone(wish everything was this easy) LOL
Chris
Old Jul 28, 2008 | 06:05 PM
bucwheat's Avatar
bucwheat
Never heard of this.
Old Jul 28, 2008 | 06:15 PM
GRUNIE's Avatar
GRUNIE
It's a common problem with the chrome after market valve stem caps being sold in all the major Corvette catalogs. The o-ring gets stuck on the valve stem especially if you really crank the cap on (to stop sticky fingers). Just pop out the o-ring in the cap prior to screwing on to the valve stem.
Old Jul 28, 2008 | 07:09 PM
rws.1's Avatar
rws.1
yup... happened to me.. I used a dental pick to get it out...
Old Jul 28, 2008 | 10:04 PM
fortunate dad's Avatar
fortunate dad
well that is just the most FAR OUT thing ever
the chuckster
Old Jul 28, 2008 | 10:20 PM
Same thing happened to me. Once I removed the O-ring, air went right in the valve stem.
Old Jul 28, 2008 | 10:37 PM
dobewillie's Avatar
dobewillie
good info
Old Jul 28, 2008 | 11:04 PM
Choreo's Avatar
Choreo
To in my valve stem?
