TPS fuse NO# location help
Old Jul 31, 2008 | 08:09 AM
OIF2XVET's Avatar
OIF2XVET
Default TPS fuse NO# location help
I am changing out my rims and tires for ones that are already mounted and balanced but do not have the TPS in them. Can someone tell me what fuse and its location to disable them so they don't keep popping up on the DIC. Thanks in advance
Old Jul 31, 2008 | 08:45 AM
poolboy's Avatar
poolboy
I know on some of the later years the TPS system can be disabled using a Tech II tool, but other than that I do not think there is a fuse that is dedicated to the TPS you can pull. The receiver for the TPS is also the receiver for remote entry, and maybe other stuff...
Old Jul 31, 2008 | 09:25 AM
Vega$Vette's Avatar
Vega$Vette
Can not be disabled on a 97.
Old Jul 31, 2008 | 10:07 AM
OIF2XVET's Avatar
OIF2XVET
sorry I forgot to mention it is for my 2000 not my 97
Old Jul 31, 2008 | 02:45 PM
c5streak's Avatar
c5streak
Sorry, but only the '01s and up can be turned off with a Tech II. However, most dealers won't turn it off for safety reasons.
Poolboy is right, the fuse also runs your keyless entry. Even if you pull the fuse, your still likely to get warnings in your DIC.
Old Jul 31, 2008 | 04:55 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Your going to get annoyed at pressing the "reset" button. I went through that for a few months before my nervous breakdown about it and had sensors put in.
To TPS fuse NO# location help
