Quick lowering bolt question
Old Aug 1, 2008 | 03:11 PM
Quick 68's Avatar
Quick 68
Default Quick lowering bolt question
I think I have decided to buy some C6 bolts for the front of my C5z as the cut bushings didn't quite give me the drop I wanted. I just wanted to confirm that the C6 bolts will lower the car more than the cut stock bolts and I was wondering where I can get the bolts. Thanks for the help.
Old Aug 1, 2008 | 03:50 PM
slothy's Avatar
slothy
yes it will lower it more, or u can just cut the stock bushings on the bolt
http://www.westcoastcorvette.com/p-4...-bolt-kit.aspx
Old Aug 1, 2008 | 03:58 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
i ahve spoke with Gene @ GmParthouse. You can not factory order c6 bolts direct without order the composite leaf springs with the bolts. No kidding. WCC is the only place for bolts only kit.
ps. you need to order FOUR (4) of them form WCC, you only need 2. Wanna split a packet of 4? Im getting ready to do this as well. PM me if interested.
otherwise, i think im going with this WCC C5 front kit:
http://www.westcoastcorvette.com/p-1...-bolt-kit.aspx
And this is the thread for the Rears:
http://forums.corvetteforum.com/show....php?t=2088457
Old Aug 1, 2008 | 05:17 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Got my C6 front bolts and longer rears from LG. Haven't had a chance to put them on yet so sorry, no pics
Old Aug 2, 2008 | 03:36 PM
Zenak's Avatar
Zenak
if you can email me a pic of the LG kit, since none in on the website?
Old Aug 2, 2008 | 04:57 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
The "kit" from LG consists of a set of C6 bolts (apparently from WCC since they are packaged in WCC wrap), and a set of longer "generic" bolts for the rear. I was told by another forum member that this is the setup he went with and it put his C5 right where I want mine to sit. You could more than likely obtain the same items from any number of vendors. This is just the direction I took.
Old Aug 2, 2008 | 06:47 PM
Zenak's Avatar
Zenak
can you post a measurement on HOW LONG those rear bolts are? thanks!
Old Aug 2, 2008 | 08:28 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
6 3/4" long.
Old Aug 3, 2008 | 11:28 AM
Zenak's Avatar
Zenak
how low is your car off the ground now with those 6 3/4 bolts? ground to body?
Old Aug 3, 2008 | 12:40 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Old Aug 3, 2008 | 01:02 PM
JAC5KSON's Avatar
JAC5KSON
does anyone have a write up on how to install them?
Old Aug 3, 2008 | 01:32 PM
2000lambovette's Avatar
2000lambovette
Several vendors sell the C-5 front lowering bolts Zip products, WCC and a few others. The C-5 front lowering bolts goes in with no trouble I never tried a C-6 front lowering bolt but I bet it is no different.
This is my car with WCC C-5 lowering kit.
Old Aug 3, 2008 | 01:34 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I haven't gotten a chance to install the new bolts yet. Hopefully soon. Take a look at "Toque's" ride. He has the perfect stance I hope to get when I lower mine more than just stock bolts.
To Quick lowering bolt question
