Window Valet problem maybe?
Old Aug 2, 2008 | 11:05 AM
pmuney's Avatar
pmuney
Default Window Valet problem maybe?
I installed a new H/U after I put on A Valet, now I cant get my aftermarket H/U to turn on. I went from a pioneer 4000UB to a 5000UB, and I know that this new 5000UB works just fine. Could it be a problem the valet caused? I know that the wires are connected well, I dont know what fuses to check however. and I have checked in the audio thread too. thanks. the ACC is connected to the 3 wires under the passenger side, maybe I should connect it to fuse #22 instead?
Old Aug 2, 2008 | 04:10 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
The Valet wouldn't have any effect I suspect, however; for a pro opinion and answers, I would recommend you post over in the Audio section. Those guys have all the answers when it comes to electronics.
Old Aug 3, 2008 | 12:43 PM
pmuney's Avatar
pmuney
ttt
Old Aug 3, 2008 | 02:33 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
OK, the Window Valet just plugs into the OBD II port. Try unplugging it and see if the problem is fixed. Easy way to diagnose the problem.
To Window Valet problem maybe?
