[Z06] What heads?
Old Aug 4, 2008 | 06:05 AM
TransAm2002's Avatar
TransAm2002
Default What heads?
Looking into a VRX5 cam, but I want to do heads as well. Should I get Patriot LS6 stage 2 or 3? Or what? I have full bolt ons with a 100-150 shot. Thanks for any help.
Old Aug 5, 2008 | 01:15 AM
TransAm2002
Hello???
Old Aug 5, 2008 | 04:14 AM
427CPE's Avatar
427CPE
AFR 205 or TFS 215. There is nothing else I would put on my car (w/a 346)
I think personally, the TFS215 is a great head. I have used both it and the 235 (402ci) now, however the AFR205 has proven itself many times and can be installed with stock pushrods(though I would replace them) and
rockers. You will need 7.5" PR and RR for the TFSs.
Also, sorry, I'm not a Patriot head fan, though I know some on this board may help you more w/those.
Old Aug 5, 2008 | 12:21 PM
VTME13's Avatar
VTME13
I'd use some ETP 215's before either AFR or TFS... my $0.02.
Everyone is going to have an opinion.
Old Aug 5, 2008 | 01:25 PM
pit-man's Avatar
pit-man
I used AFR 225's incase I decided to go all out later (which I did). The larger heads on the stock bottom end with a baby 224 cam still let me run 11.33 @ 120...third place on ZO6 fast list. Best was 124mph.
MY 2 cents with actual data. Also had unported 90mm Fast, LG Longs, ET Streets on stock gear thru stock mufflers, no cats. I thought it was pretty fast for NA with the baby cam and large heads. A better driver probably could have squeezed a lot more from it !!
Pitt
Old Aug 5, 2008 | 01:52 PM
N4cer's Avatar
N4cer
If you want a budget head like Patriot, go with Livernois. They make a great CNC'd 243 casting, and the sales guy, "Chad", is a Corvette owner as well. I had their Stage 2 243 head, and it fed my 408ci Camaro to run the same times as my buddy's L92/L76 headed car. And of course, his heads were all the rage... until I showed that the budged CNC'd heads were just as good.
(sorry if this isn't allowed)
http://www.livernoismotorsports.com/...t.phtml?p=1351
If you are going with an expensive aftermarket casting, then of course TFS and AFR are producing great, repeatable results. If I went with expensive heads, I'd do one of those as well.
Old Aug 5, 2008 | 02:12 PM
CamaroAJ's Avatar
CamaroAJ
Pro Mechanic
Pro Mechanic
IPS Motorsports heads are also very good. they are also a forum sponsor.
www.ipsmotorsports.net talk to brandon and tell him i sent you.
Old Aug 5, 2008 | 05:58 PM
VIPERBLUELX's Avatar
VIPERBLUELX
243's from TEA or find someone local to hand port them(that knows what they are doing). If you've got the big bucks get the TFS 215's.
Old Aug 5, 2008 | 06:05 PM
Higgs Boson's Avatar
Higgs Boson
Save your money and work up the stock 243s... That's what I did on a 408 and put down 685/715 on a 200 shot. The motor's built for more so maybe I'll try a 300 shot..... Hmm....
To What heads?
