DIC engine oil sensor
Old Aug 4, 2008 | 02:50 PM
tinner73's Avatar
tinner73
Default DIC engine oil sensor
i just changed the oil and when i reset the DIC it only goes to 35%??? any ideas?
Old Aug 4, 2008 | 02:53 PM
jrose7004's Avatar
jrose7004
Turn the key on but the engine not running and pump the accelerator 3 times. It should reset.
Old Aug 4, 2008 | 02:54 PM
tinner73's Avatar
tinner73
..98 vert by the way.
Old Aug 4, 2008 | 03:27 PM
ROADAPPLE's Avatar
ROADAPPLE
Use fresher oil?
Old Aug 4, 2008 | 04:03 PM
Are you sure you actually reset the oil life monitor? Try the procedure again (as outlined in your owner's manual) and hold the button down a little longer. If that doesn't reset it to 100%, try the method described above.
Old Aug 4, 2008 | 04:43 PM
tinner73's Avatar
tinner73
Originally Posted by ROADAPPLE
Use fresher oil?
whaaaaa??
Old Aug 4, 2008 | 04:45 PM
tinner73's Avatar
tinner73
when i hold down the reset button it goes...._ _ _%
then it eventually goes to 35%
Old Aug 4, 2008 | 04:58 PM
tinner73's Avatar
tinner73
THAT DID IT....THANKS GUYS.
Old Aug 4, 2008 | 05:00 PM
jrose7004's Avatar
jrose7004
To DIC engine oil sensor
