the perfect tire size?
Old Aug 5, 2008 | 08:26 AM
talon104's Avatar
talon104
Default the perfect tire size?
I know there are quite a few different answer's ,but what would be the perfect tire size for a front 18x9.5 and a 19x10 rear? The widest tire that could fit on the rim for a 2001 corvette coup without messing anything up? I see alot of different ones used, i was offered 265/35/18 fronts and 285/35/19 rears. looking at tire raack size charts these look ok, but am unsure, so thought i'd ask. is this a good setup?
gonna pull the trigger and would appreciate the input
thanks.
Old Aug 5, 2008 | 09:29 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
thanks.
^^You can go to tire rack and look yourself. They provide information on the rim they used to measure the tire on, as well as the range of rim sizes that can be used with that particular tire width.
Make sure the front tire diameter is equal to or less than the rears so you don't have problems with traction control and ABS.
Old Aug 5, 2008 | 09:40 AM
talon104's Avatar
talon104
ok, i'll look again, i must be a dumb *ss all it tells me is actual stock sizes, (what is recommended). Hum, thanks , will look again
Old Aug 5, 2008 | 09:55 AM
talon104's Avatar
talon104
Duh, ok, it shows the recommended size tire for that wheel size.I was looking for the widest size you could go, ok, thanks again Independent1
Old Aug 5, 2008 | 11:06 AM
Independent1
St. Jude Donor '08
^^Glad you found what you needed.
Happy to help.
Old Aug 5, 2008 | 02:56 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
for the rears I am running 295 x 19's on 19 inch wheels. Problem is this size is almost obsolete now, I believe Kumho is the only one listed on tirerack. the extra 10 mm does make a difference imho.
Old Aug 5, 2008 | 03:00 PM
csexton's Avatar
csexton
I'm running a 295/35/19 BFG KDW II on the rear
Chuck
Old Aug 5, 2008 | 08:16 PM
rwsr50's Avatar
rwsr50
Is there a point at which a wider tire will start throwing stuff back on your fender and tearing it all up?
Also, you have to watch the tread widths in the specs on tire rack. Sometimes a narrower size tire actually has a wider tread width than a wider size, depending on manufacturer and style. The OEM runflats, say what you want about them, have an extremely wide tread for their size.
Old Aug 5, 2008 | 08:39 PM
Dee Z06's Avatar
Dee Z06
Default tier size
I'm running 305/30/19 Nitto on the rear of my z06 love them
Old Aug 5, 2008 | 09:16 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I have 305/30/19's on 19x11 CCW 505a's on my coupe...no fitment issues and look great!!!
To the perfect tire size?
