Cam (No Heads) or Headers?
Old Aug 5, 2008 | 10:41 PM
ynotsquare's Avatar
ynotsquare
Default Cam (No Heads) or Headers?
I'm ready for my nexy mod. At first I was thinking of headers (LG). However, I've done some research and now I am thinking of installing a mild cam. I plan on doing both (I think), but not at the same time. Which would you do first?
By the way, it's a daily driver.
Old Aug 5, 2008 | 10:43 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Headers first, then the cam You can run headers w/o issue on the stock heads/cam. However a cam will be fairly choked on the stock manifolds.
Old Aug 5, 2008 | 10:52 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Old Aug 5, 2008 | 11:17 PM
500hp's Avatar
500hp
I vote for camshaft, if it's not too MILD.
Old Aug 5, 2008 | 11:21 PM
Mitch.Shea's Avatar
Mitch.Shea
I have a bigger cam on stock heads/headers with no cats on a m12 frc. cam sure will sound good and come with the most hp out of others. expect to spend up to 2k from a vendor.
Old Aug 6, 2008 | 10:54 AM
slowtealz28's Avatar
slowtealz28
Definitely do the headers first. Start small and work your way up.
Old Aug 6, 2008 | 12:27 PM
Drewstein's Avatar
Drewstein
You'll also be much happier with the increased throttle response and sound. Then when you add a cam you'll gain 70 or so rwhp.
Old Aug 6, 2008 | 12:58 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
headers 1st for sure.
Old Aug 6, 2008 | 01:05 PM
02MillenniumVette's Avatar
02MillenniumVette
Old Aug 6, 2008 | 01:32 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
You'll need'em for any future engine mods anyway. JOE
Old Aug 6, 2008 | 01:54 PM
black98c5's Avatar
black98c5
Definitely headers first.
Old Aug 6, 2008 | 02:03 PM
Purdone's Avatar
Purdone
Headers first for sure.
$2,000 for a cam? WTF? Cams are about $380. Springs will be another $400. $150 for a timing chain, and $100 for an oil pump.
Old Aug 6, 2008 | 02:08 PM
IM28702's Avatar
IM28702
I think the quote was installed....
Old Aug 6, 2008 | 04:54 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Headers
Old Aug 6, 2008 | 04:55 PM
Blow Torch's Avatar
Blow Torch
Wow; Good gains from a cam....Mine must have been too small
Old Aug 6, 2008 | 04:56 PM
TTUbaker's Avatar
TTUbaker
St. Jude Donor '08
Definitely go with the headers before you go the cam-route.
Old Aug 6, 2008 | 05:05 PM
Mitch.Shea's Avatar
Mitch.Shea
i would just save and do it all one time.
To Cam (No Heads) or Headers?
