vert back window falling out
Old Aug 6, 2008 | 10:09 AM
fastviking's Avatar
fastviking
Cruising
Default vert back window falling out
The glass for my back window on my 2000 convertible is falling out. There are two straps to keep it from falling completely out, but there is a large gap between the top of the window and the fabric top. Does anybody know what holed that glass to the fabric? Is some sort of adhesive? Where would be the best place to get it repaired?
Thank you
Old Aug 6, 2008 | 10:46 AM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Check this thread out, hope it gives you some ideas on a fix.
http://forums.corvetteforum.com/show....php?t=1766844
Old Aug 6, 2008 | 11:06 AM
cletus's Avatar
cletus
I used this fix last summer and it works perfectly! And I just used some pillows to keep pressure on the glass while it was drying...
Good luck.
Old Aug 6, 2008 | 04:45 PM
fastviking's Avatar
fastviking
Cruising
thanks dadvan...I ordered the parts already. An autobody place in town said they have tried everything but this cannot be done. I told him about the glus and gave him the site. He wants t okeep him posted as to my pogress. Thank a WHOLE lot for the information
Old Aug 6, 2008 | 06:03 PM
Tri-Blak's Avatar
Tri-Blak
I used Rhino Glue and it's holding perfectly - in heat and rain and putting the top up-and-down! I just put in some large rolled towels to hold the glass in place and I glued it from the outside all around the inner edge. The glue is amazing and can be used for other things - just store in the refrigerator.
Old Aug 6, 2008 | 07:23 PM
Awsum98's Avatar
Awsum98
Default rear window
I glued mine 2+ years now and it has stayed on like new !
No leaks or problems.
Old Aug 6, 2008 | 09:20 PM
arobber's Avatar
arobber
Sell it and buy a coupe.
Old Aug 6, 2008 | 09:27 PM
midlifetoy1's Avatar
midlifetoy1
Default vert glass
I need to try this, but I've got a couple of questions....
1. Did you take the window completly out and start from scratch?
I've noticed that there is a distinct line that shows if the window moves(I'm using double-sided tape right now and as it looses stickiness, the window shifts and the line becomes visible. As it wears out, I just reapply the tape)
2. Can I do just the top, then bottom, then the sides?
3. If you don't remove the entire window, how can you insure that the surfaces are completly clean.
I used alcohol and Goo Gone to clean the glass, but wasn't sure if I was getting the surface of the fabric clean enough
Old Aug 6, 2008 | 10:30 PM
71vetteinva's Avatar
71vetteinva
It's a funny thing. I had the same problem in my 2000 last month.
I did this last month using Gorrilla Glue. It seems to be holding up well, no leaks or anything. However, that glue expands, which means I got an unsightly gap between the window in the top. I've decided to go ahead and get a replacement. After all, the rest of the top is faded and picked in places.
The first installer I talked to told me he had just installed a new top on a 2001 and another on a 2000 (pretty sure it was an '00, he could have said '02, though)? All within a week.
I guess whatever they used to seal in the rear window only lasts about eight years.
Anyway, to answer your questions...
1. My glass was in the same position yours is. Hanging by the bottom. There was no gap when I closed the top, so I figured it was supposed to be that way. Whoops.
Eventually the whole pane fell out!
It would have been easier to glue the window while it was still in place. Be warned, the bottom could also be a loose. Don't tug on the back glass or the whole thing could slide out.
2. I would glue it all at once. I think there is less chance of bunching.
3. Your glass will adhere to a plastic lip attached to the top. Just wipe it with alcohol.
I think this problem was exacerbated by how I put the top up. I would simply lift the top out of the trunk by grabbing it on the driver's side (like the owner's manual says!). That puts quite a bit of torque on the top.
As a matter of fact, I was putting the top up in this matter when I heard a crackling noise. That was the glue giving way. The top immediate fell away from the top. Adhesives simply don't do well when the material is twisted away from them.
I've found the top goes up faster and easier if I simply lean forward and grab the obvious handle in the middle of the top. Hopefully that will prevent wear and tear on my new top!
Old Aug 7, 2008 | 11:50 AM
waupachino's Avatar
waupachino
I almost made the same mistake as you last month. Gorilla Glue does expand and it states that on the bottle. Rhino Glue does not. Luckily I used Rhino Glue which I was only able to find on-line, has worked perfectly to date.
To vert back window falling out
