Recommended Aggressive Alignment?
Old Aug 6, 2008 | 05:59 PM
RrCoX22's Avatar
RrCoX22
Default Recommended Aggressive Alignment?
Someone recommended me to get my alignment done to specs:
-2 camber - front
-1.3 camber - back
zero toe out - front
.25" toe in - back
what about the caster?
Old Aug 6, 2008 | 09:12 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
-2 camber - front
-1.3 camber - back
.25" toe in - back
That's a TON of negative camber dude... You will surely go through tires fast. Camber/caster settings still rely on a lot of factors...
How much inside turn in bite do you want (more caster). 7-8 degrees is stock.
How soft is your suspension? (more roll = more camber = more caster reaction = bad)
How low is the car? (active camber changes accelerate once arms go below parallel).
What type of track? (short turns, autocross? Road Atlanta? Daytona?)
Top speed? (you want these suckers to be planted in the straight too, right?)
-2 degrees camber is very extreme dude. Do you have a bump steer kit? Do you have a camber kit?
If it were me I'd get practice at the stock setting, then go extreme with ONE setting (camber before caster) so you can feel the real difference, then adjust.
I hope my rambling helped.
Old Aug 6, 2008 | 10:55 PM
Bill Dearborn's Avatar
Bill Dearborn
-2 camber - front
-1.3 camber - back
.25" toe in - back
What are you trying to do?
With that much camber you are maxing out the cams on the lower control arms and removing all washers from behind the upper control arms which means you will be limited to about 4 degrees of caster.
On the street you will be wearing out the inside edge of the front tires.
Bill
Old Aug 7, 2008 | 03:03 PM
RrCoX22's Avatar
RrCoX22
ya that's what I figured... forgot to mention that it's lowered all the way down on stock bolts.
what do you guys recommend for aggressive street use and general road courses.
Old Aug 7, 2008 | 03:06 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I think every car is different! ! ! What are your intentions..............................
Old Aug 8, 2008 | 08:39 AM
devnull's Avatar
devnull
I would seriously recommend using the flat stock setting. If you are lowered, active camber will react more than stock height anyway. Get some hard sways and see how it feels. Change only one thing at a time and see how the difference feels.
Old Aug 8, 2008 | 11:44 AM
thetaxman's Avatar
thetaxman
I've been playing around with the settings
I'm at 4 degrees caster and like the change
also if you lowered the car you need to check the bumpsteer
To Recommended Aggressive Alignment?
