Exhaust Cutouts OR LT & X-pipe???
I've been debating now about which to do. I really only want to do one or the other. The longtubes and x-pipe are definitely more pricey and seem to cost a lot for the hp they provide.
Anyone have dyno info on before and after with cutouts installed?
Actually I think you'll find that longtubes are pretty high up on the list of hp/$$.
Cutouts will provide you very little hp and very much noise.
My other main issue with the aftermarket longtubes is that most if not all will not bolt up to the stock cats. Aftermarket cats are no good since they are just as illegal as running no cats.
Keep reading on the forum and you'll see that real hp gains from the cat-back are in the 5-10 hp range and most are suspect. Most here will tell you that cat-back systems are for sound quality only, not performance.
Hp gains from longtubes are in the 25-40 range and solidly documented. The cat-back is NOT the most restrictive part of the exhaust, the manifolds are.
Read more, think it over, and do what you will. I don't have either one. I'm going strictly on what has been posted here before.
Good luck.
Good luck.
Why would they provide little hp? If they dump either before or after the cats, they would eliminate any hp loss through the balance of the system.
I now have Kooks long tubes with high flow cats and no pre-cats. They are legal and passed emissions testing in Texas. CA is a lot tougher, so I don't know what systems would pass there.
I used to have TPIS long tubes on my car. They eliminate the pre-cat a.k.a. the "pup" cat. They use the stock cats. See pic below. TPIS on the left, stock exhaust on the right.
