Heads up display
My car has the Heads Up display and it works, but I can't get the image to center on the windshield. I've gone up and down with the toggle switch, and the image goes down but won't come up high enough to see without sitting very foward in the seat.
I looked briefly around the forum and didn't find anything discussing this problem. Anyone have any clue to this problem ?
Joe
Congrats on your car. The HUD will only be visible in the lower portion of the windshield. You can't get it to where it's centered between the dash and the top of the windshield. At it's highest, its only an inch or two above the hood when you look at it.
How tall are you? I would suggest you try adjusting the seat as well to get things lined up. Let us know what happens.
Also, polarized sun glasses will cancel out the HUD and you won't see anything. Several of us learned that from experience.
Enjoy your new ride.
You can get to the projector, but it is not simple. You would need to follow the instructions for the HUD installation where you remove the entire dashboard. It's been awhile since I did it, but it would probably take about an hour or so for removal.
When I, all 5'10", oh all right, 5'9", of me sits in the seat, there is no HUD. None. If I sit up close enough to put my chin on the steering wheel, I can see the HUD. The toggle makes it disappear completely. As I stated, my friends C-5 has the display high enough that I could see it immediately. I had never seen such a thing before. When I first laid eyes on my car, I assumed that I had misunderstood about the HUD.
Anyway, this just sounds like something that in not sitting squarely in the dash. Like it's too high or too low in the front or back. I'm guessing the cost to replace the HUD is a lot.
Thank you for all your advice so far.
Joe
It definitely sounds like the pivot bolt is broken IF your havin to sit up in the seat all the way to the steering wheel just to see it. It isn't too bad to take out. Here are the instructions (this actually covers adding a HUD to a non-HUD car but you'll see how to get to it)
http://forums.corvetteforum.com/show....php?t=2077521
It really does look A LOT worse than it actually is. Your first time it'll probably take ya about an hour or so. Once you've done it though, ya can have the whole dash out in about 20 min.
Any way I would also love to know how to fix this without replacing the projector. I dont know if too many people on here have taken apart a projector to know what's broken inside of it, but it sure would be nice to fix instead of replace since everything else works on it. Looks like we're on our own to figure it out.
If anyone needs a projector, a friend of mine has one and is askin $200 plus shipping for it. However, once you get the unit out and take it apart (I think about 4-6 screws hold the assembly together after ya get it out of the car) you'll see the part that's the issue pretty clearly. Lemme get my old HUD out and take some pics.
Now when i put my head against the visor, i can see just the top of the RPM range of the hud display. I havent had a chance to get into the dash yet because id ont know how to take it apart
my height button doesnt move the hud anymore which makes me believe it broke and slipped out completely.
When you have to lean up to the steering wheel just to see your HUD, this is what the cause is. First, once you've removed the HUD using these instructions here:http://forums.corvetteforum.com/show....php?t=2077521
Once you have the HUD out, remove these four screws:
After you get the four screws out, you can then open up the HUD housing. **BE CAREFUL AS THERE IS A WIRE CONNECTED** (shown below)
Next, remove these three screws to remove the HUD mirror and bracket:
Once you get this off, be careful as there are wires going to the bracket.
Notice the blue line? Well there's supposed to be a tit that sticks out there and inserts into the hole where the red arrow points. That allows it to pivot back and fourth. If you look in your HUD, you'll find this small tit somewhere in there (as it couldn't go anywhere)
Unfortuantely you can't reattach it. As you can see, I even tried to epoxy a tit but it didn't work.
You can take the two screws that hold the bracket on the mirror out and separate it.
and then have it off.
After looking at it again, I'm going to try to drill out the hole on the bracket above and insert a small enough bolt that will fit through the hole it pivots in (pictured above with the red arrow)
I'll let everyone know what I find.
