[Z06] Can i???
Old Aug 9, 2008 | 10:31 PM
ls2SS's Avatar
ls2SS
Default Can i???
Run a 19/20in setup on my 01 Z? I talked to a rep at toyo he told me in order to run anything on the car other than factory rims have to run a 21in rim in rear to be correct for sus setup....for the car the ride smooth and like it should...
anyone with rims.??? how does your car ride?
Old Aug 9, 2008 | 10:42 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Several members have 19/20 set ups. The important thing is that your overall diameter of the front wheel/tire combo does not exceed the overall diameter of the rear wheel/tire combo. The height/overall diameter is as much a function of tire choice as wheel diameter.
The issue isn't suspension related, it is electronic stability control related ie traction control.
I have 19" rims on all 4 corners and the car rides/handles better to me than it did with factory tires/rims.
