MAF Coupler
Old Aug 10, 2008 | 10:29 PM
tah81's Avatar
tah81
Default MAF Coupler
I'm looking for a new coupler between the MAF and the airbridge. Does anyone know who sells them or is there a Home Depot or Lowes item that will work? I see a lot of smooth couplers from the airbridge to the throttle body (two different diameter ends) but not the MAF to airbridge. Thanks.
Old Aug 11, 2008 | 06:35 PM
tah81's Avatar
tah81
Anyone??
Old Aug 11, 2008 | 06:42 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
You mean like this?
I got it from Ecklers. Of course I live in Florida and get delievery the next day. It ia also available through MidAmerica and other Corvette parts suppliers.
Old Aug 11, 2008 | 06:44 PM
hotwheels57's Avatar
hotwheels57
Assuming you're talking about the oem system...
You could contact Gene at GMPARTSHOUSE, a site supporting vendor listed in the column to the left on the main menu page. He'll have oem genuine GM parts at a good price.
If you're talking about some after market system, contact the manufacturer or after market suppliers of "silicone reducer" or "silicone coupler" (internet search keywords). You're going to need to know the exact OD/ID of the MAF and airbridge and coupler so you don't experience any air leaks and codes.
The plumbing products found in the home improvement stores are best left to be used for their intended purpose. Most are inferior rubber, not heat resistant silicone, and are not intended for use in a hot engine compartment. Again, you'll probably experience eventual air leaks. I've experienced that personally with my former '96 Impala SS with an LT1. The heat cracked the DIY intake creating all kinds of issues.
It's your car to do with as you please.
Old Aug 11, 2008 | 08:21 PM
MagRedConv's Avatar
MagRedConv
Pretty much any supporting vendor in the left margin.
Old Aug 13, 2008 | 08:01 PM
tah81's Avatar
tah81
No one has the MAF to airbridge coupler, everyone has the airbridge to TB coupler.
Old Mar 30, 2009 | 03:53 PM
34RedRage's Avatar
34RedRage
Originally Posted by TR6speed
You mean like this?
dude, that sure is a clean looking engine compartment...
To MAF Coupler
