Lowering on stock bolts???
Old Aug 12, 2008 | 10:04 AM
ALVETTE00's Avatar
ALVETTE00
Default Lowering on stock bolts???
Really dumb ?...
That lowering bolt seems to be accessible as is, why do you have to remove shocks and all the other stuff to do this?
http://www.digitalcorvettes.com/foru...ad.php?t=26211
al
Old Aug 12, 2008 | 10:12 AM
stod16's Avatar
stod16
well sometimes u can get lucky and turn the bolts down. some times you cant. my pass side spun with it all intact. the drivers side it was so stuck in there i stripped the bolt and ending up taking the hole front suspension out to get the bolt out. There is sprung weight on the bolts and thats what makes them hard to turn.
Old Aug 12, 2008 | 10:49 AM
RRM707's Avatar
RRM707
It's not dumb at all, & many have done it. There's no need to remove anything to do it. It's actually quite simple too.
I think it took me less than an hour, to do the front & back.
Give it a try!
Here is the link:
http://www.z06vette.com/diy_lower.php
Old Aug 12, 2008 | 11:17 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Im confused, why did he removed the shocks? ? ? ?
Old Aug 12, 2008 | 11:30 AM
ALVETTE00's Avatar
ALVETTE00
Give it a try!
Here is the link:
Thanks buddy...I figured you could alleviate the tension an easier way -as illustrated in your link!
I may try this during the next oil change.
Old Aug 12, 2008 | 11:34 AM
slothy's Avatar
slothy
ya spray the bolts (specially fronts) a few days in advance to make it even easier
Old Aug 12, 2008 | 01:37 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Been there, done that. Seems like the fronts (my passenger side)are always the problem ones. Glad you got it done.
Old Aug 12, 2008 | 10:27 PM
ALVETTE00's Avatar
ALVETTE00
Just curious...
What affect does this have on the handling/cornering?
Old Aug 12, 2008 | 10:43 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by ALVETTE00
Just curious...
Positive results...your lowering the center of gravity of the car. combine that with performance shocks like Bilstein Sports and Z06 sway bars. Car will be like its on rails!
Old Aug 12, 2008 | 10:47 PM
renegad44's Avatar
renegad44
Just curious...
After I lowered mine I went ahead and installed new C6-Z06 shocks and C5-Z06 sway bars w/metal endlinks, had it aligned and to me the handling is superb especially in cornering on spirited runs, there’s not that leaning/swaying side to side on cornering, it’s tight, but that’s mostly due to the sway bars. There’s guys here that could give you a more technical explanation, and I would welcome one also. I'm satisfied.
^ Right above me, see what I mean, a very good explanation...thanks "Ikester"
Old Aug 12, 2008 | 11:05 PM
lionelhutz's Avatar
lionelhutz
You need to take the spring pressure off the A-arm.
Put the car up on jack stands. Put the jack under the spring in the Y of the lower arm with a piece of wood or something else that won't damage it between the jack pad and the spring. Jack it up enough to lift the spring off the lower arm. Now adjust the bolt.
Peter
Old Aug 13, 2008 | 08:56 AM
bgray's Avatar
bgray
Peter
I didn't remove the shocks and hit the bolts with PB Penetrant.
To Lowering on stock bolts???
