C5 Bezel Question
Old Aug 13, 2008 | 08:34 AM
rmtt's Avatar
rmtt
Default C5 Bezel Question
After reading through all of the posts concerning these bezels on the forum, I had a few questions.
1. What seems to be the general cosensus on adhering these things to the instrument cluster? I have seen "super-glue, gel, 3M tape, clear silicone, and most recently black RTV".
2. Out of those listed above, which have had the best results as far as staying on, and not "fogging" up the plastic?
Thanks for any additional insight as I really like the looks of this mod.
Oh...I have also come across some threads where they used a paint pen to achieve the same result, but this looks like it would be kind of hard unless you had an "artist's touch".
Old Aug 13, 2008 | 10:15 AM
Big Als01's Avatar
Big Als01
I used Super-Glue Gel. Put them on this last winter and have had NO problems. NO Fogging either. Be sure not to put the gauge cluster back together for at least 24 hrs. Let the glue dry real good, then you won't have a problem with fogging.
Allen
Old Aug 13, 2008 | 10:18 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Allen
I've had mine one for 4 yrs -- no problemo.
Just use real "krazy" glue --- I heard the stuff that comes with the bezels is junk (2 other people I knew who used that stuff had bezels fall off after a yr in CA sun),
.02¢ added
Dave
Old Aug 13, 2008 | 10:24 AM
bucwheat's Avatar
bucwheat
What bezels are you guys talking about? Pic's?
Old Aug 13, 2008 | 11:10 AM
11yellowgscpe's Avatar
11yellowgscpe
The aluminum bezels on the gauges. I used super glue a year ago, no problems
Old Oct 11, 2008 | 05:56 PM
cyber-vette's Avatar
cyber-vette
I purchased a set off Ebay for $55 and the Tach and Speedo bezels did not fit correctly. I ended up heating the aluminum and opening the diameter so they fit correctly. I used the superglue that came with the kit. Plan on keeping the car parked for a few days as the glue needs alot of time to cure.
I left a fan blowing on it overnight and the next morning the glue smell was gone.
Old Oct 11, 2008 | 08:14 PM
davek 515's Avatar
davek 515
I used super glue last Feb. and have had no issues as of yet. I love the look of the bezels.
Old Oct 11, 2008 | 08:22 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default well I will be the oddball
I bought a set from Josh at RPI. My set needed some bending to get them to fit properly and I used the superglue gel. I left the cover off all night and checked on it in the morning. The glue ruined my bezels and more importantly my cluster! the glue due to some humidity, attached it's fumes all over my bezels and my cluster. White residue on everything. I tried everything to clean it. Nothing worked. Totally ruined it. Apparently, don't try to glue these on with humidity over 60%. I talked to Josh and explained everything and he said he honestly never heard of this type of reaction. I agreed and said, "me neither". He sent me free of charge another set of bezels and deeply apologized for the problem. I explained that I felt it was not his fault or a bad product but that I just must of "lucked out" and had all the worst case scenarios add up and bite me.
I ended up taking the lemons I was given and made lemonade out of it. I have since repainted my cluster a two tone airbrush design to match my underhood design and reinstalled the new bezels Josh from RPI sent me. This time I used the black RTV and that worked like a champ. I for one would highly recommend you use the RTV silicone. The silicone won't fog anything, plus silicone flexes. The glue over time will get hard and brittle and the gauges will fall off.
Old Oct 11, 2008 | 08:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Bought mine from LAPD maybe 4-5 years ago, and used the glue that was suppled. It seemed like really strong stuff, just like superglue.
Been on the car for ~3 years now with no problems. I applied them to a painted surface though, not sure if that makes any difference.
Old Oct 11, 2008 | 11:18 PM
tlc0706's Avatar
tlc0706
That's cool
To C5 Bezel Question
