[Z06] 2003 Z06 Shifting into Reverse
Old Aug 13, 2008 | 11:14 AM
61 Silver's Avatar
61 Silver
Default 2003 Z06 Shifting into Reverse
I just purchased a 2003 Z06 with 15,000 miles. When I test drove the car I did not notice the reverse shifting problem. When I try to shift into reverse the transmission does not engage and makes a strange noise. I shift back to neutral and then into reverse and it will engage the transmission. Has anyone had this problem and if so what did you do to fix it.
Thanks for any information!
Ray
Old Aug 13, 2008 | 11:26 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Are you sure you are getting it into gear the frist time??? I have an 03 Z and mine seems a little hard to get into reverse once in a while, but does not make any noise... It almost like it gets bound up some how..I just take it back to neutral and then it goes right in..
Old Aug 13, 2008 | 11:42 AM
kerryt1's Avatar
kerryt1
I have the same problem on my 03Z and my 05 CTS-V. Just back to neutral and a blip of the throttle, back into R.
Old Aug 13, 2008 | 12:13 PM
rockerdudez06's Avatar
rockerdudez06
Yep I have 2001 and that has happend a few times.Find em and grind em.
Old Aug 13, 2008 | 09:49 PM
61 Silver's Avatar
61 Silver
Thanks for the help!
Ray
Old Aug 13, 2008 | 10:38 PM
wannagofast's Avatar
wannagofast
Lots of times I just shift into first then reverse
Old Aug 13, 2008 | 11:35 PM
tlc0706's Avatar
tlc0706
It IS very difficult to look cool when you slide in your shiny Vette and grind the he** out of your gears with 3 or 4 people watching. Try going from neutral to 3rd then into reverse...should make ya look better to the watchers...
Old Aug 14, 2008 | 01:14 PM
Moike's Avatar
Moike
I do this everytime and it goes right into R.
Old Aug 14, 2008 | 06:14 PM
froggy47's Avatar
froggy47
Old Aug 14, 2008 | 09:47 PM
61 Silver's Avatar
61 Silver
Thanks for all the information! There is a big difference from the 1961 to the 2003 ZO6.
Ray
Old Aug 15, 2008 | 10:25 AM
FasterIsBetter's Avatar
FasterIsBetter
I hate to be the bearer of bad tidings, but I had the same problem with my former '03 Z06, and it was the first sign of transmission problems. I often had to shift to neutral and sometime even into 4th, let the clutch out a tad, and then over into reverse. It got worse over time, and later started having trouble getting into 3rd gear, shifting up or down, under power. Ended up doing a tranny replacement. When they pulled the old tranny, the synchros were all but gone.
Hopefully yours is the run of the mill reverse problem that lots of folks seem to have with the T56 tranny. I have it now and then with the 2004 Z when it's cold. Once the car warms up, it's fine.
Old Aug 16, 2008 | 02:42 AM
striper's Avatar
striper
I guess it does seem to be the nature of the beast, mine does it too!
Old Aug 18, 2008 | 07:37 AM
Cobra_4's Avatar
Cobra_4
St. Jude Donor '09
Mine does the exact same thing. Ill go days with no problem, then when I get in front of someone she seems like she always screws up!
Old Aug 18, 2008 | 07:51 AM
briann510's Avatar
briann510
Just pull forward in 1st a couple inches and then into reverse while barely creeping forward still and it will go right in. Mine has been doing it since day one and it doesnt mean squat about tranny problems about to happen as I now have 40K on it and tranny is fine..
Old Aug 18, 2008 | 10:59 AM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
Since day one as well. I always park it in 1st and rarely have to ease it forward before it takes reverse.
Speed
To 2003 Z06 Shifting into Reverse
