Lowering Bolts
Old Aug 13, 2008 | 03:56 PM
jserio's Avatar
jserio
O.C.
Default Lowering Bolts
I'm long overdue for a stupid question.
Where do you raise/lower the car from? I need to raise my up up a tad. I'm as low as a lawn mower.
Old Aug 13, 2008 | 03:59 PM
stod16's Avatar
stod16
there are 2 bolts on the front out on the leaf spring near the shock turn them counterclockwise and make the bolt shorter from the top view. out back there are 2 longer bolts at the end of the leaf springs again tighten them up and it will make you higher
Old Aug 13, 2008 | 04:00 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
https://www.corvetteforum.com/techti...D=90&TopicID=1
Peace
Chip
__________________
..................Click for
Old Aug 13, 2008 | 05:54 PM
jserio's Avatar
jserio
O.C.
Thanks Guys.
Chip, Do you need to go thru all those steps to raise the car up?
Old Aug 13, 2008 | 05:58 PM
CCA Corvette Parts
Originally Posted by jserio
Thanks Guys.
No,
Just referenced the "how to" to show you where the lowering bolts were
http://www.customcorvetteaccessories...weringkit.html
I just jacked up the front, did those, let it down, jacked up the back and did those...
Peace
Chip
Old Aug 13, 2008 | 07:59 PM
jserio's Avatar
jserio
O.C.
Good Call, Thank you.
Old Aug 13, 2008 | 08:01 PM
jserio's Avatar
jserio
O.C.
OOO, One last thing. Do you know how many full turns it would take to rise .5 inch? This would be very helpful.
Old Aug 13, 2008 | 08:39 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Thanks Guys.
He is just being detailed! !
Old Aug 13, 2008 | 08:58 PM
CCA Corvette Parts
That's the nice way to say it Mike
Peace
Chip
Old Aug 14, 2008 | 06:39 PM
jserio's Avatar
jserio
O.C.
Any idea how many full turns of the wrench for a half inch raise.
Old Aug 14, 2008 | 09:01 PM
CCA Corvette Parts
Just mark the bolt or count the threads
Peace
Chip
Old Aug 15, 2008 | 12:02 AM
ToplessBlonde's Avatar
ToplessBlonde
Default You may have to adjust it more than once to get the look you want.
Correct me if I'm wrong.
Guys? Doesn't the suspension need to adjust to the change??
I just lowered mine on the stock bolts. When we were finished, I swore I would have to lower it more. But after a day or 2 she settled down and is exactly where I want her.
Old Aug 15, 2008 | 12:08 AM
Wadsfrc's Avatar
Wadsfrc
Thats true with a base suspension car, a Z51 or Z06 won't settle as much.
Old Aug 15, 2008 | 12:43 AM
nuck's Avatar
nuck
If you are that low the fronts may have been cut in which case they need to be replaced. C5 bolts aren't serviced as a separate piece so you need to buy the ones for sale cor C6s.
http://forums.corvetteforum.com/show...959&highlight=
Old Aug 15, 2008 | 02:54 AM
IDM's Avatar
IDM
I have a set of c5 and a set of c6 front bolts with bushings if anyone needs them
To Lowering Bolts
