Removing front emblem?
Old Aug 13, 2008 | 05:22 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
Default Removing front emblem?
Aloha,
Since I can't get the search function to work I came to the experts. My front nose emblem is trashed and I have a new one to put on. How do I go about removing the old one?
Many thanks in advance..
Old Aug 13, 2008 | 05:28 PM
hotwheels57's Avatar
hotwheels57
It's installed by GM with double sided tape and two alignment pins.
Use sunlight or applied heat to soften the adhesive and dental floss or thin fishing line to saw cut. Rub off any adhesive left on the surface with your fingers...blisters will heal in about a week.
Clean with denatured alcohol. Apply new emblem. Aloha.
Old Aug 13, 2008 | 05:54 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
isn't the front held on with posts?
Old Aug 13, 2008 | 05:57 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
True, but they just pop right out of the holes.
Old Aug 13, 2008 | 06:03 PM
KonaVette's Avatar
KonaVette
Thanks hotwheels...looking forward to the blisters
Old Aug 13, 2008 | 11:09 PM
Use a hair dryer to soften the tape and then take a piece of fishing line and saw through the tape. There are two pins that go into the front fasica, so you'll have to work around them.
Old Aug 14, 2008 | 12:05 AM
BATM4N's Avatar
BATM4N
Send me the emblem. I bought the car for the front emblem
Old Aug 14, 2008 | 03:11 AM
jdmvette's Avatar
jdmvette
Night Owl for life
you don't need to heat the emblem.
also use goof-off to remove the adhesive.
Old Aug 14, 2008 | 10:14 PM
KonaVette's Avatar
KonaVette
Thanks for the help guys... will get after it this weekend
Old Aug 14, 2008 | 10:28 PM
10U 99's Avatar
10U 99
Originally Posted by jdmvette
I have a pair of those chrome emblems on the way, should have them tomorrow and installed this weekend.
To Removing front emblem?
