Wipers Don't Work HELP PLEASE!
Old Aug 15, 2008 | 09:03 AM
redneck34's Avatar
redneck34
Default Wipers Don't Work HELP PLEASE!
Good morning, I have 99 6-speed convertible and the wipers won't work, the washers work, I was wondering if anyone knows what circuit, fuse or relay they run on? I looked at the fuse boxes diagrams and it doesn't show which one for the wiper motor.............thanks .......Steve
Old Aug 15, 2008 | 01:10 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Don't knw which fuse it is for sure, but your owners manual will tell you. Check your udders tere are three of them behind the WSW box reach under and milk them to make sure the motor well has not filled up with water. They do sometimes and short out the WS wiper motor.
Old Aug 15, 2008 | 02:25 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
25A mini fuse #10 in the IP fuse box is for the wipers and washer pump. If your washer pump is working the fuse is not the problem. Do the wipers operate when washer is running?
www.moroso.com
Old Aug 15, 2008 | 02:33 PM
JAFE's Avatar
JAFE
Had to replace my motor as the motor well was filled with trash.
Old Aug 15, 2008 | 03:14 PM
khblair's Avatar
khblair
Cruise-In 9-10 Veteran
St. Jude Donor '08-'09-'10
what do you need wipers for??? you arent supposed to drive it in the rain - it melts!!!!!!!!!!
Old Aug 17, 2008 | 06:18 PM
redneck34's Avatar
redneck34
Hi, it was the trash build up in the three rubber udders............thanks..............St eve
To Wipers Don't Work HELP PLEASE!
