Broke hood mount... ideas?
Thanks!!
You may have to cut the back side for access, then have a body shop have at it.
This site has an image of what you're probably dealing with...
http://www.emhart.com/products/pop/popnut.asp
Short of replacing the hood, your idea of relieving a hole and using a nut on the other side is probably the only option.
However, you make not be able to remove the damaged rivet nut to replace it with a hex head nut.
What's probably occurred is that someone has tightened it down to much and the flanges have worn away on the underside of the fiberglass pocket. That's why the insert is just spinning now.
Drilling it out is a possibility, but it's steel and will more than likely just spin, enlarging the hole and/or damaging the fiberglass even further.
IF, you can access the inside of the hood area via an access hole, you might get lucky and be able to grasp the insert with a small set of needle nose VICEGRIPS.
Then you might be able to thread in the metric bolt and tighten if, further compressing the flanges on either side of the fiberglass. It takes some effort to do that. If you can secure it from spinning, then maybe drilling the top flange is possible...then use the fastener/nut arrangement. You'll need fender washers on the both sides if that's successful.
It's definitely a long shot and that fastener will always be a weak point...
... a little closer
I tried to find the torque specs but the source I checked didn't have the torque value. Someone might chime in. Just snug it up until you determine the correct specs.
"Toothed" washers are more for electrical ground connections. If you can get a flat washer under the new nut/split lock washer, it would be extra support, but maybe not needed since the metal structure is there.
They must mold that metal structure in there for just this reason. Maybe the spot weld on the oem nut broke loose? When I suggested the "rivnut", I didn't even consider a metal subframe in there.
Maybe you can find a plug of some type to fill in the hole?
