Door Edge Guards!?? Please help.
Old Aug 15, 2008 | 04:07 PM
prplprl2's Avatar
prplprl2
Default Door Edge Guards!?? Please help.
Yes, I know...why would you put these on your C5? Well, the PO put these on the car (along the vertical/rear edge of the door) to cover up some minor dings/scrapes. The ones he put on are too small/narrow and keep tryinging to come off. This exposes adhesive and just generally looks like bunk!!!
I have looked to try and find something that will fit as a replacement until I can get the doors touched up. The C5 door edge is much wider than standard doors and I cannot find any that are wide enough to fit.
Does anyone out there know where to find these for a C5?
Thank you.
Old Aug 15, 2008 | 04:13 PM
hotwheels57's Avatar
hotwheels57
If you have any large automotive paint supply vendors in your immediate area, you might check with them. They usually carry various types of oem moldings in addition to paint supplies.
Using keywords of what you're looking for might yield some hits on internet sources...
Old Aug 15, 2008 | 04:20 PM
prplprl2's Avatar
prplprl2
[QUOTE=
Using keywords of what you're looking for might yield some hits on internet sources...[/QUOTE]
Thanks. I have tried various on line searches and keep coming up empty. What I have found is pretty much the same thing that is on it now.
I also tried searching the forum and most of the threads on this topic are too old to still show up.
Thanks.
Old Aug 15, 2008 | 04:27 PM
bucwheat's Avatar
bucwheat
I bought mine from Pep Boys,they have many colors also.
Old Aug 15, 2008 | 07:27 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Thank you.
Hey prplprl2 Is the issue for you the adhesive being exposed? If so go to the hardware store and buy some goof off... Thats what people use to get the adhesive off when they remove the body side moldings.
search BSM and JDMvette for more info if thats what you need
Old Aug 15, 2008 | 09:40 PM
prplprl2's Avatar
prplprl2
Thanks TBRENT.
Not sure if my concern is the nasty looking adhesive or the nasty looking scuffs covered up by the adhesive?
I I think I will hit Pep Boys to see if I can find some guards, then take old ones off and clean them up. If it looks okay then I will not put the new ones on. If it looks bad...cover em up. Thanks.
To Door Edge Guards!?? Please help.
