Aluminum Gage Bezel Mod
Old Aug 16, 2008 | 03:37 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Default Aluminum Gage Bezel Mod
Just completed this mod, and it looks great! However, I noticed today that there is some sort of "white stuff" on the surface of the instrument cluster, which I didn't see when I was installing the bezels. Anyone that has done this mod...do you know what it is? More importantly, do you know how to remove it? I don't have a problem with taking everything apart again, but I need to clean it up and don't know what product to use. Any input would be appreciated.
Old Aug 16, 2008 | 03:53 PM
stormrider's Avatar
stormrider
How long did you wait before reinstalling the gauges? You have to wait about 12 hours to let the fumes evaporate.
Old Aug 16, 2008 | 05:20 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Ever seen CSI where they use superglue fumes to highlight fingerprints.
I didn't have the same issue, but I did use some plastic polish to take some scratches out of mine. I believe it was Meguiar's brand.
Old Aug 16, 2008 | 11:17 PM
z06 hellcat's Avatar
z06 hellcat
use black rtv silicone, this will solve your problem!
Old Aug 17, 2008 | 03:58 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Is it on the Lense or the Black Surround? The lense should clean up easily, but I'd be damn careful with the surround, the paint treatment on it is very fragile, you'd be better off trying to cover it up with something...
Old Aug 17, 2008 | 01:04 PM
RJ1AZ's Avatar
RJ1AZ
That would make a difference. I was thinking the clear cover had fogged.
To Aluminum Gage Bezel Mod
